cadman
I know we have some typewriter fans in the group that might appreciate this. Recently I finally closed the deal on an IBM 2741. This is a heavy-duty version of the Selectric outfitted for computer interface work. Fortunately, it was completely overhauled in 1994 and it doesn't seem to have seen much use since.
Part of the challenge has been figuring out the 55-pin non-standard connector, and in typical IBM fashion, there's error checking built-in that creates a lot of additional wiring, fortunately I'm 99% there.
Anyhow, one of the first things I noticed was a cracked and sagging carrier cord pulley. It seems these go bad on ALL Selectrics. The reason for this post, however, is that it appears new and improved replacements are now available. Mine arrived tonight and works great! I opted for the rebuilt assembly which appears to use a delron/aluminum slide pair that's a much better design than the original.
So, if you have a Selectric stashed away because of this ailment, break out your wallet and have a look at the link below! -Cory
http://www.typewriters.com/selectric-parts.html
