Servel Propane Refrigerator
Compare to these ebay new gas fridge specs
E-Z Freeze Propane Refrigerator 10 cu. ft. #1050W White
Burner BTU/hr 1500
Fuel consumption (24hrs): .25 gal/1.1 lb
Refrigerator Net Weight: 170 lbs.
E-Z Freeze Propane Refrigerator 21 cu. ft. #2150W
Burner BTU/hr 1700
Fuel consumption (24hrs): .35 gal/1.5 lb
Refrigerator Net Weight: 253 lbs.
A 20 lb propane tank is usually filled with 17 or 18 lbs of propane to allow for gas expansion. Some places the exchange tanks are only filled to 15 Lb.
As a swag I will assume that propane costs 1 buck per Lb.
That means that 10 cuft fridge costs 1.1 bucks per day; 33 per month per swagish swap meet math.
That means that 21 cuft fridge costs 1.5 bucks per day; 45 per month per swagish swap meet math.
Locally some folks have an emergency hurricane fridge or one for a rural hunters site/cabin that runs on propane; when/where there is no elecricity.
Bigger unit uses less gas per volume of fridge than smaller
Note how the one fridge is 2.10 times larger (21/10) but only uses 1.36 more gas (1.5/1.1)
This is typical since surface area (heat loss) grows as the square, and the volume grows as the cube.
ie a 1 ft cube has 1 cubic feet of volume and 6 cubic feet of surface area
ie a 2 ft cube has 8 cubic feet of volume and 24 cubic feet of surface area
smaller objects have a higher surface area to volume ratio than big objects.
That's what this Servel was being used for. The people that I got it from had a very rural cabin that they go to for vacation, and so do the people who bought it from me. It's an expensive way for them to have refrigeration, but at least they have it, and in a full size fridge.
Had no idea about the recall....Wild.
NEWS from CPSC
U.S. Consumer Product Safety Commission
Office of Information and Public Affairs Washington, DC 20207
FOR IMMEDIATE RELEASE
July 22, 1998
Release # 98-145 Company Phone Number: (800) 782-7431
CPSC Consumer Hotline: (800) 638-2772
CPSC Media Contact: Ken Giles, (301) 504-7052
CPSC, Warns That Old Servel Gas Refrigerators Still In Use Can Be Deadly
WASHINGTON, D.C. - Government safety experts continue to warn consumers to stop using Servel gas refrigerators manufactured between 1933 and 1957 due to the risk of carbon monoxide leakage in deadly quantities.
The U.S. Consumer Product Safety Commission (CPSC) reports there have been at least 39 incidents in the U.S. involving these old Servel gas refrigerators, causing 22 carbon monoxide-related deaths and 55 injuries nationwide. There also have been incidents reported in Ontario, Canada, causing 60 deaths.
Because historical sales and distribution records of these early Servel models are unavailable, it is not possible to determine who still owns and uses these refrigerators. The Servels continue to be used in hunting cabins, vacation cottages and remote areas of the nation where there is no electricity, or where gas is the preferred energy source.
Over a period of time, especially if the refrigerator has not been used recently, the gas burner can be fouled by dust, dirt, rust or other obstructions. Any gas refrigerator with an improperly adjusted or partially plugged burner can produce substantial amounts of carbon monoxide.
Consumers can call the Servel Corrective Action Committee (SCAC) toll free at (800) 782-7431 anytime to receive a rebate package that includes instructions for disposing of their Servel gas refrigerator. Consumers who properly dispose of their old Servels will receive a $100 rebate plus reimbursement for reasonable disposal costs.
Since this recall program was launched in 1990, more than 22,000 refrigerators have been destroyed. On average, 100 new requests for rebates are mailed to SCAC monthly, demonstrating that there are still many more in use.
Consumers who insist on keeping their old Servel refrigerators should move them to an outdoor shelter, shed or garage not connected to the house or cottage. CPSC urges owners to secure or restrict access to refrigerators kept outside and, when discarding any refrigerator, to remove its door. This will prevent children from playing in the refrigerator and possibly getting trapped and suffocating inside.
CPSC advises that all gas refrigerators be serviced regularly by licensed technicians in order to assure their safe operation. They also should be inspected after they are moved and before they are turned on after a seasonal shutdown. Special attention should be paid to blockages in burners and flues.
No longer in business, Servel manufactured gas refrigerators between 1933 and 1957. The Servel refrigerators in question are no longer being produced and are in no way associated with the Dometic Corp., the current manufacturer of Servel brand name products.
Servel Gas Refrigerator Servel Gas Refrigerator
The U.S. Consumer Product Safety Commission is charged with protecting the public from unreasonable risks of injury or death from thousands of types of consumer products under the agency's jurisdiction. The CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical, or mechanical hazard. The CPSC's work to ensure the safety of consumer products - such as toys, cribs, power tools, cigarette lighters, and household chemicals - contributed significantly to the decline in the rate of deaths and injuries associated with consumer products over the past 30 years.
To report a dangerous product or a product-related injury, call CPSC's Hotline at (800) 638-2772 or CPSC's teletypewriter at (301) 595-7054. To join a CPSC e-mail subscription list, please go to https://www.cpsc.gov/cpsclist.aspx. Consumers can obtain recall and gener
The gas friges we sell (Dometic)work well and can be either gas or a/c. They sell for $1399 and are 9 cu ft.The only issue we have is when the owner/user doesn't have two seperate tanks so that,once one is empty,they can switch the gas feed over to the other. When this happens and the gas is out,most of them have to be "burped" before they can be turned on again.
RISK; some folks have no issues and use them still today
There are several folks I know that own old gas refrigerators and purposely ignore the "crushing them".
Like any risk; one could took crush old cars without seatbelts; or crush non double insulated tools, or buy up all the old sonic blasters, yoyos, clackers and crush them.
One has gobs of folks one once had common sense and had no issues with many things today deemed as totally risky.
All one really has to do is keep the old gas device in good order; and use a CO alarm if really scared.
Government safety experts continue to warn consumers because folks are basically stupider, more assuming, have less common sense. Crushing units drops the liability.
We had a gas refrigerator when I grew up and I never heard of CO issues; but at time a local repair man maintained them and one had less of a doofus factor like today.
Personally I have heard of more deaths by folks using propane heaters inside; or electric portable heaters; or gas generators than old gas refrigerators; but their usage is probably 100,000 times more
