Quartz
Steve,
Which, in the pic above, is the left machine with the door fully open?
After the pressure vessel pipe split on the Sapphire, as Ian, Grandma's washer engineer showed me, I notice, looking at your pic above, the machine on the left looks exactly identical to the Sapphire's setup, part location wise, with the metal bar across the top from either side.
Btw, any Servis owners, what's the deal with these machines having them wretched "PITA" vents on the rear panel for? When the pressure vessel pipe'd split, it caused the Sapphire to overfill, thus ending up with water pouring out one of these said vents & causing a lovely lagoon of water over the garage floor, soaking everything in the streams path.
Also, what's with the necessity of having the inlets on the side of the back panel, instead of a simple, conventional machine like my Logic Premier?
Steve, Paul, Mike, I'm not sure if you're aware, but ZodaWash (Not to confuse Sesteve, with ZodaWash Steve), sold me his Quartz 6036G, which he posted on GumTree & Ebay, he kindly delivered it to my house, only being an hour from his place, on June 17th, so his Quartz's been rescued by a Servis enthusiast, who's now got, currently, 03 different models of Servis...
A 1982 Servis Quartz 04KG 1000RPM AutoWasher Mk600.
A 1983 Servis Quartz 04KG 1000RPM AutoWasher 6036G.
A 1989 Servis Sapphire AutoWash/Dry 04KG 1300RPM Washer Dryer 9635.
The Mk600 is ultimately destined for Aquarius8000's capable ownership, the Sapphire & Quartz 6036G will remain with me, once a reshuffle's complete, the Quartz will sit next to the Sapphire where my trusty Zanussi JetSytem WJD1667W currently resides, which's going to my Grandma, due to it being more suited to her needs than her current Ultima WD860, therefore making way for ZodaWash's Quartz.
Paul or Mike, maybe you could confirm the below thoughts/beliefs?
I noticed that, after Aquarius8000's acquisition of his Servis 3305, that the porthole is different to my Sapphire (Chris, I've borrowed one of your pics, for comparison only, hope you don't mind?), why has my Sapphire got a glass, Míele style porthole glass? Rather than the seemingly standard plastic, flat, porthole that the Mk600, Chris's 3305, & my new Quartz sport?
Was it to deflect the heat back into the drum/load? Rather than it being lost through the door glass & heat shield of the door? Don't forget, the Sapphire's a Washer Dryer, not an AutoWasher.
CJ
