Servis Quartz Club
Servis Models
Deconstruction/Don,
The Servis Quartz & Sapphires have what are known as 1/2 panel doors.
There were two varieties mainly, with the third being very rare:
01) 1/2 panel door with plastic porthole window with target pattern (AutoWashers).
02) 1/2 panel door with sloping glass porthole (Washer Dryers).
03) Décor full panel with 1/2 panel door with plastic porthole window with target pattern, behind outer door.
I've been lucky to own most variations of these machines, Sapphire AutoSelect 6065, Quartz 6104 & 6036G, Quartz Mk600, all autowashers & a Sapphire 9700 washer dryer etc, all since Oct 2011.
I still have in daily operation my Sapphire 9635 washer dryer, & its brother, the 9634, the only differences between model codes being cabinet & trim colours.
I believe the only Quartz model that featured a décor full panel door, concealing the 1/2 panel door behind, was a model 6032 (confirmed from my range brochure), I'll post snaps below of each machine I've had, and a Sapphire snap, showing the example of the 6032.
All Quartz's both 603- & Mk600 models were all 1000RPM spin machines with the exception of the 6104 which was a 1100RPM model.
Only selected Sapphire models had a 1300RPM spin speed, the AutoSelect 6065, AutoWash 6055, my ex 9700, now with a friend, & my two, the 9634/9635 were all 1300RPM.
There was an Electra badged Quartz style washer dryer. Snapped up by ChesterMikeUK (the #01 authority on Servis).
http://www.automaticwasher.org/TD/AWJPEG/VINTAGE/2011/hooverzanmiele++5-17-2011-18-09-30.jpg
Anyway, I'll leave y'all for now with a selection of snaps of the machines I've had & the Sapphire equivalent style of the 6032.
Key of snaps as follows:
01/02) Quartz 6036G.
03) Quartz 6104.
04/05) Sapphire AutoSelect 6065.
06) Sapphire AutoSelect 6065/Sapphire 9635, showing door porthole variation.
07) Quartz Mk600.
08) Sapphires 9700/9635, set up for use (Original use set up).
09) Sapphire 9700.
10) Sapphire 9634 (Left), 9635 (Right).
11) Sapphire/9635 full décor door (NOT REAL, self edited version!).
12) Sapphire 9634/9635 1/2 décor door no porthole (NOT REAL, self edited version!).
13) Quartz 6032 (The REAL one).
14) Quartz 6030/6031 1/2 panel no porthole. ]
15) Quartz 6030/6031 1/2 panel with porthole.
(Stephen, hope you don't mind me borrowing a self edited copy of snaps 14/15 from your booklet?).
If any of this description is confusing, I'll apologise now!
If you wish the full table of Servis models for reference, I'm sure Mike will happily oblige and post a copy up for y'all.
CJ
Chronology of Models
Don,
In Reply #18, Paul's given an outline of models, however I think I've seen a more in depth table Mike created & posted somewhere, but Mike'll re-post if you want, I'm sure.
Servis Quartz 600 door seal
My Mother-in-law has a Servis Quartz 600 washing machine made in 1983. The door seal has gone and as it is in a fitted kitchen, in a gap only 58.5 wide, we can not replace the machine and so far I have been unable to get hold of a new seal. The washing machine is in pristine condition apart from that and she is very keen to carry on using it. I would be very grateful if anyone can help
Thanks a lot.
Servis Door Seal
Hi, your mother in law's kitchen won't have been the only kitchen built around a Servis 585mm cabinet I'm sure! Gaskets are still available, and pretty reasonably priced. I've got 2 of these machines, just stripped and rebuilt one just last week and thats had a new gasket too. Attached is a link to one on eBay, give us a shout if you have any problems with it in the future! (Or if its ever up for disposal!)
Hope this helps!
Chris
http://www.ebay.co.uk/itm/Door-Gask...558819?hash=item46546420a3:g:52UAAOSwxg5XzqHi
Replacement door port hole galass 6036G
Is there anyware I can get a replacement port hole glass foe a Servis M6036 also a replacement gasket I see a number on this site but not for servis M6036
6033G
At very long last I have started to investigate my 6033G.
To begin with thank you to those who have posted tips and information.
Today I dug the machine out and manoeuvred it into a suitable position. After a quick look around for broken / bare wires I provided power and saw the comforting LED in the display.
Then opened the front door and observed that the door seal has dematerialised so that's the first problem - I imagine that this will be very difficult to find :(
Around at the back with all the covers off, I found that a little rubber hose which runs from a round thing (which has electrical connections) near the top of the cabinet then down and around the back of the drum case to a little plastic 'bottle' ( a water-level sensor?) has corroded almost completely where it fits onto the 'bottle' - a very simple fix :)
Apart from that the only other visible issue is the broken, flattened and jammed wheels - but I can deal with them.
So the first challenge is the door seal. Anyone, any tips? :)
6033G
I think I forgot to actually post a previous message after previewing it :) so here it is (again).
Thank you for the link, I have sent chestermike a message on EBAY.
The small-bore rubber tube has been replaced (old cars are one of my other hobbies).
And I've cleaned out some dust and spiders' webs. There are a few patches of rust on the inside of the cabinet and some rusty threads but I will wait until I'm sure the machine works before dismantling it to recondition these.
The drain-pump seemed a bit grimy so I took it out and cleaned it up a bit. I suppose I could test that on the workbench.
So that broken rubber pipe is part of a pressure-sensing system? What might be the effect of the system being open?
Are any technical drawings and manuals of the 603x available?
Return Of The Quartz
The project continues.
The little rubber-pipe has been replaced and I managed to obtain a new door-seal and fit it (!@#).
After putting some water into the drum through the soap-tray to check for leaks there was a dribble from the seal at the drum joint but tightening the retaining-band stopped it.
With no other problems apparent, I decided to risk a programme.
Chose E (30° 'quickwash') and started it.
Familiar, comforting sights and sounds: both water valves opened and the machine filled, the drum turned now and again, no leaks or strange noises but after about 1 minute, an error-code - alternating F and 4 - appeared in the display and the action stopped.
Drained the machine manually by lowering the drain hose.
So, questions:
1. what does F4 mean?
2. does anyone have a list of all error-codes?
3. is it possible to get the machine to empty using the keys? i.e. get the drain-pump to run
Of course slightly disappointing but realistically it's still progress because this 6033 hasn't been run since 1997!
As always grateful for any advice :)
Return...
Just found some codes online; could someone confirm if these are correct for the 6033?
F1
Water heating error detected
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
<ul>
<li>Check water heating element </li>
<li>Check heater for contunuity </li>
<li>Check thermistor or temperature sensor </li>
<li>Check the thermistor resistance </li>
<li>Check wiring to water heating element </li>
<li>Check connections to water heating element and temperature sensor </li>
</ul>
F2
Water fill time out
The washing machine has failed to fill with water in a reasonable time.
<ul>
<li>Check water supply is on, clear and not frozen </li>
<li>Check the air chamber and pressure sensor hose for blockages </li>
<li>Check water inlet valve </li>
<li>Check wiring to water inlet valve </li>
<li>Check connections to water inlet valve </li>
<li>Check the main control PCB </li>
</ul>
F3
Not drained in time allowed
Washing machine fails to drain water
<ul>
<li>Check that filter is not blocked or obstructed </li>
<li>Check drain hose is clear of any blockage or obstruction </li>
<li>Check wiring to drain pump </li>
<li>Check drain pump is not defective </li>
<li>Check level sensor or switch </li>
<li>Check wiring to level sensor </li>
</ul>
F4
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine, although this was very rare in these old Servis washing machines.
<ul>
<li>Check the pressure sensor and that the machine has not actually overfilled with water. </li>
<li>Check for overfoaming or over soaping </li>
<li>Check the air chamber and the pressure switch hose </li>
<li>Check water level sensor </li>
<li>Check wiring to water pressure sensor </li>
<li>Check connections to water level sensor </li>
<li>Check main electronic controller </li>
</ul>
F5
Water heater fault
This fault code tells you that the washing machine has detected an error with the wash heating element.
<ul>
<li>Check water heating element</li>
</ul>
Servis Quartz-Error F4
Hi deconstruction, just found your post. The error code F4 almost certainly relates to a motor/tacho fault.First thing to do is remove the "power-board", the PCB down beside the motor & check that the motor hasn't blown the board, which is normally visually evident, the large connector at the bottom of the PCB as you look at it.
If you're lucky, it might just be a case of the motor brushes/carbone needing replaced.If the PCB/board is blown, I can perhaps help with that if you're of a mind to fix it.Personally, I'm looking for a motor for a servis Quartz 6035, if you've 1 of those kickin' about.
6033G F4
Thank you for the suggestions.
I do not have a motor for 6035, sorry.
I will have a look at the PCB and report back here.
Do you mean the brushes of the main motor? It does revolve the drum a little, without unpleasant noises.
6033 brushes
Then even if they still work I should replace them.
These - from gcr-suffolk and ebay - look right but Servis is not listed, only Creda, Electra, Gala, Hotpoint etc.
Can anyone confirm if these are suitable or, if not, a part reference number for the correct carbons?
I'm not 100% certain but I think these are GEC motors so they should fit - I don't have a parts list to check but you can find these brushes quite readily and cheaply on Ebay so just check around for cost as they are quite universal. I think even though I have had mine to bits (as above) I never looked at the motor as that seemed to be the bit that was working fine!
The power board looks fine and F$ is a motor tacho fault - motor too fast or too slow so the brushes are a good place to start along with the tacho coil at the back of the motor.
Take a couple more pictures of the motor if you get the chance.
S
6033G motor
Thanks for the advice.
I decided to risk a pair of carbons offered on EBAY (not expensive).
And one evening this week I might manage a photograph of the motor (the machine is now wrapped up again so that birds do not get into it
6033G motor
So, after a pause of a few weeks I have had another go at the machine.
The new carbons seem not to fit. The basic design / form is very similar but there are several detail differences. At first I thought that it was only an updated design but there is a problem: they slide into the motor in the same way but not quite far enough to allow the retaining wings to clear the body of the motor and so they will not lock into place.
Are there many different types of carbon?
Is cleaning the armature essential?
I attach photographs of the motor sticker and of the original (black) and new (grey-blue) carbons.
As luck would have it I have my quartz stripped down as I fixed the heating issue but there was a leak and the bearing seal needed replacing. I will update with some pictures on all that when it's back together and working.
I've taken the motor off today to look at the brushes and they are worn right down so am replacing them. My new ones are held together with an elastic band to keep the carbon in its holder but the ones you have have a small tab that you need to bend to release the brush from its holder so it pops out and ends up springing in and out. They should fit as it's a basic GEC motor the same as the hotpoints and those are the right brushes. I've had to push quite firmly to get them to lock in place - much easier with the motor out of the machine.
I would give it another try and see as I can't see from your pictures why they wouldn't fit.
S
6033G motor brushes
Thank you for the advice.
It occurred to me later that the problem seems only to be that the new brush-unit will not lock in place. This is caused by the length of the wings.
Otherwise the fit seems to be good (and all I have to do is push in the little tab to allow the carbon rod to spring out onto the armature).
So perhaps I should trim the wings...
