vague memory...
I think you take off the rubber tyre and underneath there is a grub screw you remove with an allen key.
The screw might not be under the tyre, it might be on the hub, I don't remember. It was over 20 years ago I last played with one of these. But it is there... Look on the shaft, if you can see a flat, that is where the grub screw will be.
