Servis super twin service
adam-aussie-vac
Dec 14, 2017
1,085
Canberra ACT
Hey guys, does anybody have any knowledge on how to remove the pulley driven pump from The Twin tub, as the seal in the pump has gone and I’m wanting to repair it so I can get it into working order or if worse comes to worse replace it with an electric pump
vague memory...
I think you take off the rubber tyre and underneath there is a grub screw you remove with an allen key.
The screw might not be under the tyre, it might be on the hub, I don't remember. It was over 20 years ago I last played with one of these. But it is there... Look on the shaft, if you can see a flat, that is where the grub screw will be.
Remove the entire pump
That is the easy bit.
It's a single bolt through the body of the pump. Maybe 1/2 inch nut?
Should be pretty obvious. Just undo the nut, then slide the pump off the stud (bolt.)
You can see the nut clearly in photo 2. Near the pulley.
I think its the nut where the straw is ! Move the pump back and forth and see where it pivots thats usually the bolt that holds it on.
So I’ve taken the pump apart completely, where would I find the seal for it and I noticed how there are appears to be some sort of little oiling well thing in the pump shaft, would that help create a seal or what?
It came from the shaft And previously
And There was an issue where previously one hour was trying to drain the washtub, the pump wouldn’t prime but once it was primed it would Leak water from where the shaft is I honestly am kind of thinking about changing it to an electric pump But I don’t want to unless the original pump I can’t really repair
@adam aussie vac
Hmm I think it most likely would not turn as never known a Servis pump to not be primed, But a first time for everything...
Try cleaning all the gunk off the shaft I have a suspicion that the leak may not be repairable as there is no seal to my knowledge inside it was done bu machining a very smooth tight fitting shaft and you were right the oil in that port made it water tight all you can do is clean it all and grease it and see if you can get it to work.
But if not maybe a replacement could work instead?
Oh cool, I didn’t realise it was such a tight seal
That oil actually makes the seal, that’s kind of surprising, I’ll try probably putting some three in one oil into it and then making sure that seals hopefully,
To replace the seal is easy . If it’s a standard lip seal these are available from all good bearing shops . The shaft should be made of of a non ferrous metal. Take a photo of the seal and post it . I’ve taken seals out and they have fallen to bits so i have taken the pump body and the impeller shaft and the seal shop will measure the diameters for you and get the correct size . The shaft size is the most critical element as the outer seal size can be bonded in using a good gasket silicone . I’ve found this works fine . Good luck but it’s an easy fix this is a pump I refurbed for a friend a few weeks ago . The seal is brand new . Best wishes Darren
Most can be saved
This is the pump before repair
You can see it’s not good plenty of holes . The red colour inside is a resin concoction I make to protect the metal surfaces from the water and soap to prevent further problems down the line …
Gasket
If I have no originals I always use thin pond liner . Make a template out of the top of the pump
And where the screw fixings go through I use a hole punch …you can get off cuts very cheaply off eBay ..
Fair play
You have gotten further into a Servis pump than I have . I also see there is a groove around the shaft that would indicate a small O ring type of seal but as Darren has shown above he goes way deeper than I do when it comes to restoring anything. He does a superb job too as I have seen the finished articles.
Take the pump
When you go to the bearing shop take the pump
Body and impeller . The rubber seal will have perished and won’t be a true size . Get them to measure the metal parts . I always give the pump
A good cleaning up with the Dremel … keep us posted with the progress ..
Great news, I went to the bearing shop and back
And I’ve installed it, it doesn’t appear early but I’ve got a realign the pump to its pulley The pulley that measures with the pump wheel after filling it up with water it doesn’t appear to leak, but it’s not pumping with water in it so it probably means that the shaft aren’t lined up properly
It’s a pile of work to electrify
Post a couple
Of photos of the pump in situ and let’s see if it’s resolvable …
Does the drive pulley spin ?
Partially, not very fast
As if it has trouble catching up, and water was leaking where the oil Goes into the pump, Past the seal that I already installed it fits on the shaft and it seems to gently slide in, do you think it might be the seal is not sealing to The outside of the pump?
