Servis TT 2 in 1 pipe.
ozzie908
Jan 23, 2011
1,944
Lincoln UK
After much pondering and trying to find the needed bits I have at last been able to replicate a modern version of a 60's classic.
The Servis Twin Tub 2 in 1 pipe is once again fitted and working a treat.
Austin
The first pic shows the machine with 2 hoses.
Spot on Mike
Yes both valves only water out its the only way I could think of doing it !
I will have to find the Serial number but yes its cream, I have a MK1 now as well I am working on which is mostly white with a retro green panel just like the one you have, But its going to be sprayed white along with the casing as I wanted an all white one as that was what my Mums was.
Lance if you want it done to yours I can do so very easily and Hmm thank you ever so for the Hoovermatic :)
Not told himself yet I have some more coming lol will have to do some thinning out !
Austin
Thanks Ozzie
I shall look forward to my two hose twinny being converted.
Mike , thanks to both you and Darren .
I did inffact repair the rubber mount and it's absolutely water tight but thank you very much to you both for your advice.
Ozzie is hopefully coming up soon to have a go at the rest of the hoovermatics problems then I think it's going home with him to Lincoln .
2nd Hole
Its made to hold the filler hose as it has the same shape fixing as the spin rinse, I assume its just for making it possible to close the lid of the wash tub while you fill it. Never used it myself apart from to store the 2nd hose before conversion.
Maybe our Mike can shed more light on it than I ?
Austin
It would be better if you could find some plain rubber hose rather than the ribbed stuff, which is really meant to have rubber cuffs at the ends.
hoses
Ozzie thats a really great little job you have done . I like the fact that when the back panel is on you don't see any of the gubbins. The twin line hoses are like hens teeth these days but your conversion is brilliant. Pleased you got the machine done and working again.
Thank you ....
To everyone for their positive comments :)
I agree with Fido some plain grey hose would have been better but this was all I could find.
Slowspin as you know it would not have been possible without you !
Austin
Twinline Hose / Hose Restorer...
Dear All,
Does anyone know any good rubber restorer ? I have a Servis twinline hose in store but every year that goes by it is getting weaker and weaker, I have been using "Son of a gun" silicone spray restorer but just wondered if international friends have good experience with any other products ??
Cheers
Keith
@adam aussievac
I will measure them for you but it may take a while as they are in the back of the half renovated shed. I do remember purchasing the one way valves from a boat chandler and they have graduations on them to fit all sizes, as for the Y piece it was from eBay I will see what I can find out for you.
Austin
Keith I too used son of a gun applied liberally and put the pipe in a plastic bag to allow absorption of said product its stopping further disintegration but its not on the machine yet !
Oh thank you so much
Speaking of which, I brought both my Y fitting and the two one way valves and they are 19 mm , I’m planning to use some radiator hose to run from the Wash/spin tubsThrough the check valve and finish at the Y fitting Would 19 mm be okay to fit the wash and spin tubs?
@adam aussievac
I see no reason why 19mm won't work the 17mm pushes onto the hose snugly so as long as you tighten the clamps around the ends I see no issue. Pics and what have you please we like to see what's happening....
Austin
Sure thing, I’ll take some pictures
Of what I’m currently using as a modern twinline hose replacement, As I am hoping to make it into a single hose like a standard washing machine,I’m using two Fisher and pykal dish drawer hosesHow’s the modern equivalent to the original twinline hose, I’m planning to replace the hose that runs from the washtub/spin tub with radiator hoses As they would be able To handle the temperature of the hot water coming out of the washtub, Please do excuse the zip ties around the motor as they are what prevents the motor from twisting around when it starts, as due to the pulley that is now on there the original belt is too short for it so this is how I got it to work
@adam aussievac
I think your machine will heave a sigh of relief when it gets the newer 2in1 pipe fitted as the F&P dish drawer pipes are too narrow to allow the water to escape as quickly as intended. Its an ingenious work around to carry you over till you do it though :)
Austin
By the way
I’m not sure if the bearings have gone for the spinner, have a bit of a listen in comparison between these two Wilkins servis machines The first one is what I think it should sound like, The second one would be what mine would sound like
@adam aussievac
I would say they need a good oiling including the pump as its sounding like its been dry for some time. If you can get at the bearings easily enough drop some oil in them see if it helps...
I would turn the whole thing upside down and run oil down the spinner shaft and yes ok the bearings may want replacing but its not as bad as some I have encountered.
Keep us posted. Austin
I’m not sure who you’re calling Austin, the names Adam
I’m a little bit worried about flipping the machine over as Wouldn't any oil or grease from the transmission leak out of the transmission and onto the machine internally? Also would the Transmission have a breather hole of some sort? I don’t want to flip it over until after I hear back
@adam aussievac
Hi Adam I have posted all my replies to you same as I have this one !!
I believe there is a breather hole but it should not be too hard to locate and stop it up.
Have not encountered any major leaking of oil when I have turned mine over I don't leave it too long just enough to oil the moving parts I cannot get at normally !
Austin
