Sharp automatic washers
eddy1210
May 20, 2001
666
Burnaby BC Canada
Having just come back from the Philippines, I'd like to share a washer that was briefly discussed before that I experienced there:  the Sharp stainless steel solid tub!  I first heard about this on RevinKevin's thread about his trip to the Philippines, a member mentioned these,  but there were no pictures. I saw many of those same machines that Kevin saw on my trip and I won't post duplicate pictures of them, but I will post these.  It's a true solid tub machine, however, it neutral drains through perforations in the wash impeller when the valve opens.  It's a gravity drain machine, like many of them are, as floor drains are very common there. It spins the water from the clothes though, up and out the top much like the Blackstone.  These machines even have the option of an overflow rinse!  There is only one intake water valve, so if you want a fill other than tepid (cold water tap), you have to add that manually. A very fascinating machine and one that I would own if I lived there.
What is that thing sticking out into the middle of the tub? How does that work?
I'll admit, this is a very strange machine, with some odd features thrown in.
the filter
This machine does have a tiny pump that recirculates  water taken from under the wash plate into the filter.  There is also a pressure switch under the plate for water level detection.
Wow Eddy that is interesting it really is almost Blackstonesh.
I wonder in the tub does the water goes over the top..
Pretty cool washer thinks for posting.
Blackstone Tub.
Apparently, power in the Philippines is 220 volts but at 60 hz.
It's making me wonder what would need to be to done to convert it to 120 volts @ 60 hz? I wonder if it has a universal switching power supply?
