Should I repair my washing machine or not?
Wayne4910
Jul 2, 2025
I own a Whirlpool washing machine that’s became very loud during the spin cycle with no vibrations. Works fine, it’s just very noisy during any spin cycle.
I don’t know how old it is. Still cleans my clothes and works.
The model number is WTW4816FW0.
A loud, sometimes described as "freight train like" sound usually points towards a bearing issue.
As far as I understand, the bearings are integrated into the gear case assembly.
A quick google search points towards anywhere between 160$ and 260$ for the part.
Question then is if you can do the repair yourself - if not you can probably say about the same im labour charges.
Given similar washers from a Whirlpool brand (Amana, Maytag, Whirlpool) or competitors can be had for 500-600$, it really depends on the circumstances.
If you can't do the job yourself, it's probably not worth it.
If the machine is older, the risk of other failures is higher makeing it probably not worth it.
If the machine is pretty new, you can do the job yourself and you can get the part cheap, it might be worth it.
If you find the serial number on the service tag, some on here might be abled to decode it and tell you how old it is.
VMW, needs a transmission which will exceed the price of the entire machine. Time to go shopping. DO NOT get another one of these, look into a Speed Queen TC5003 if you want a top loader or an LG for a front loader.
Is that referencing the cost of it when it was purchased/new, or the used resale value?
The parts source I typically use, I can get a transmission for $193.55, incl shipping & tax. There are other sources for less, including eBay (used and new).
