Siemens "modular" DW - aka compact built-in
henene4
Feb 6, 2013
4,488
Heidenheim a.d. Brenz (Germany)
First post on the new interface - hope this looks ok in the end...
Every few years I go on holiday with my mum. We usually rent out a flat in a costal town on the north sea coast where my family has been going since basically the dawn of time.
I would lie if I didn't say I was drawn to this flat because of this DW.
It's basically a typical BSH DW - just the compact DWs, built into the size of a typical oven (60cm by 60cm - there's a 45cm height version as well).
It cleans like you would expect and dries surprisingly well.
It's by no means quiet - mostly because there's nothing underneath it and it couples a decent chunk of noise to the cabinetry.
But neither is it incredibly loud.
A few things stick out though. The racking isn't great - maybe it's just the dishes, but you have to leave out that one specific slot for plates as they hit each other because of the small rod of the rack itself.
This does have a heat exchanger it drains at the beginning of the cycle - but it will always cavitate heavily before it starts filling further and that is quite noisy.
In general, it doesn't appear to be much adapted compared to its big brothers. I don't think the soil sensor has been adapted at all for the smaller load sizes in this - if you don't run it on VarioSpeed, the Auto cycle basically always runs the same 2h cycle - at least it did the 5 or so times we ran it on that.
And it tends to leave a weird "scum line" at the front edge of the tank.
One thing the parts list mentions is a flow diverter, which appears to be activated electronically.
But I don't think I've heard it doing that at all.
Maybe it's just active on the rating cycle?
But on Auto it appears to run both arms at once - and on VarioSpeed on all other cycles as well.
    1.3 MB
    807.7 KB
    1.2 MB
    1,019.9 KB
    1 MB
    960.7 KB
    1 MB
    1.2 MB
    778.4 KB
Yes, that's what they were designed for.
They fit in a standard width slot for built in appliances, so your ovens, steamers, microwaves.
They are available in 2 heights - full and reduced, so for 60cm and 45cm heights.
The lower height models basically eliminate the upper rack seen on this model and only fit slightly smaller plates (28cm) AFAIK.
The 45cm height models have basically the exact same internals as the countertop BSH DWs, the 60cm height models are slightly modified with a heat exchanger and such.
These are made in Spain like the countertop models are AFAIK and not made in Dillingen in Germany.
Thanks for the pics, was always really intrigued by these.
They sold these here for a while maybe 10 years or so ago. They had one sitting gathering dust in the John Lewis outlet near where I used to live for years, never seemed to have garnered much interest which I suppose makes sense as it is such a niche appliance.
Jon
Fascinating! I didn't know this size format existed. It looks like a big compromise on space inside, and I thought the old standard tubs were small compared to what we have now... this makes those look cavernous by comparison. I think this is one of those instances where sure, it's better than no DW at all but I'd rather have a portable 18 or 24 than that since it has more height
