Siemens WR47B2C40 - A review
henene4
Feb 6, 2013
4,468
Heidenheim a.d. Brenz (Germany)
This is Siemens first A-class dryer, with a completly new base design.
TL;DR: If you don't plan on using VarioSpeed all to frequently and can live with 3h drying times, I don't think you'll find a better dryer.
The "nerd" review:
Quality is - as with the washer - as good as you'd expect. The new filter design is a bit annoying as it forces you to take out both filters every time you want to clean the inner filter.
The main reason that annoys me is the fine filter being coated in mostly dust. Getting stuff off of it dry without getting it everywhere is impossible.
The door is 100% plastic, insinde and out. That dosen't feel as low quality as it sounds, even though it's baffling to me the door hook is metal and the front cover is 150€ as a spare part even though it's just plastic, not glass. What IS an issue is static: On this particular model, the front plastic is kinda almost piano black looking, and the entire door is so staticy, dust clings to it and is immediatly visible. Which is kind of a bummer given every time you try to clean the fluff out there's a minor dust cloud.
But drum and controls do feel way higher quality than the VZug -the VZug dryer REALLY isn't worth its price compared to this.
And HOLY SMOKES this thing is quiet. Sitting at my desk, with the bathroom door open, my 45db Miele DW 1m from my ear is SIGNIFICATLY more audible than the dryer about 3m away.
With zippers and such, the dryer is basically inaudible.
I was standing in front of the dryer the first time and thougt, it would ramp up the fan motor at some point, or speed up the drum - only to realise it was already running.
With Speed selected, the compressor is almost annoingly noisy compared to the rest of the dryer.
With that selected, there is a high pitched electronic noise I can hear - I think that's kinda like with old tube TVs that younger people will hear that, most older people probably not.
The condensate pump however could almost be consideren noisy - but it only runs during the self cleaning and maybe once or twice during the cycle.
And then there is the star of the show: This thing is PACKED with inverters.
Compressor, drum motor, the SEPERATE fan motor and even the condensate pump.
And it does just not tangle ANYTHING. A full load if jeans, sweat pants and hoddies? No issue. Bedding, regardless of what mixed wiht what in which size? No issue.
Most cycles do 5min symetrical tumbling. Cottons does start reversing about 15-20min into the cycle when the first full sensing is done and time is adjusted. Most other cycles start right away.
The Bedding cycle does take 3min for sensing before doing 40sec one way, 10sec the other, for the entirety of the cycle.
Sensing is also done really well. I did not have to adjust ANY drying levels in the settings.
Now, the topic of economy and cycle times.
By default, it is not quick - but by no means slow. I dried 40 T-Shirts, with some underwear and 3 pairs of shorts, spun at 1600rpm, on Cottons Cupboard dry, as default, and it was done in about 3h15min, using only .9kWh. Temps never really got above 50C (guessing by checking the temp of the air path cover in the back with my infrared thermometer, and it topped out at 45C approx.).
Most cycles start with sensing. Fan and drum motor use between 80 and 110W, depending on load size.
Then, the compressor starts ramping up to about 300W total machine power. After a very short time, the compressor rpm is again lowered and the total machine power ends up somehwere between 210 and 250W, depending on temp.
You do see the power creeping up slowly as the temp rises, but in default mode, it usually does not end up above 300W.
I then did a comparison test with some towels on the towels cycle.
The loads were basically the same - the only difference was that one towel of the same size was of similar quality, but from a different brand.
Without Speed, that load took about 2:30h on Towels as it comes defaulted, and used about .6kWh.
With Speed, the load took almost exactly half the time - but used 50% more energy. Drying result was basically the same.
But, VarioSpeed does NOT care about clothing care or energy usage. Regardless of cycle (from the ones I tried), it ramps the compressor in steps up to 550W total machine power. That quickly climbs to 850W as the machine heats up - and that does happen in about 30min. If the power is consitently above 850W (machines rated power draw) it does step down the compressor speed slightly as needed and then ends up at about 750W.
And temps get AT LEAST 20°C higher. The highest temp reading I got off of the air path was near 70C - so easily 75°C air coming into the drum. And not only towards the end of the cycle, but 30min in.
I personally don't care about cycle times in the 3h range, especially with such a quiet machine. Having the option to speed up the occasional load is great.
If you do care about cycle times and think you'll use the Speed option frequently, you might end up with a more gentle, equally fast and slightly more efficent version with a C-class dryer from BSH, that's also a few hundred bucks cheaper.
But - at least sub 1000€ - this dryer is AMAZING.
It is about 10% more efficent than my B-rated VZug, it does not tangle, it is quieter than any dryer I ever used. And it's not a 4h dryer - at most a 3h dryer.
I would gladly say that - as long as you don't need very fast drying regularly - this DEFINETLY a buy recomendation.
Okay, another week has passed and you might have gotten even more experience with the dryer.
Any new opinions?
How do you like the filter set-up? I tried once more time with the display model at my store and I still don't like it, as it feels tricky to open. I liked the one the condenser dryer the most, even though it was the same design as the filter on my current heap-pump. I think the increased airflow deposits lint all over the filter, which wasn't the case with the condenser. My routine, pretty much since day one, has been to vacuum both filters after each cycle (unless I'm laundering my shirts that produce almost no lint). That also gets rid of lint that it is sort of embedded in the fine mesh. I had a laugh at Bosch's politically correct statement of washing the filters but capturing the water in a bucket and straining it through a fine filter, so microplastic won't get into the sewage. True... but who would do that?!
Makes me wonder whether we could get A-class dryers if we just went back to having large filters in the door, like dryers used to have before the introduction of glass doors. Just add a camera and watch the clothes tumble on your phone. 😜
Yes, static makes the black panels attract dust. I suppose you either have to ignore it, have a Swiffer at the ready or - as I do - wipe them down with water a drop of softener, which kills static.
Noise. That thing is so quiet, isn't it? I wish Bosch had put some sound insulation around the compressor on mine like LG does - but it guess it gets too hot(?).
Does the cleaning happen at the end of the cycle? Someone commented on my YouTube that it cleans the back every 50 cycles. Lots of lint in the water tank or do you have it set up to drain into the washer's drain?
You said it runs cool most of the time? I guess there's no cool-down cycle at the end?
Great to hear it reverses frequently. I would imagine it could also increase the drum speed periodically to "pull apart" large loads, much like washer do. Haven't seen any dryer do that, though.
Great to hear you like the dryer. It's kindo mind-boggling to see how much was changed with this platform to squeeze out a little more energy efficiency compared to B-Class dryers that use the old design.
I still really love the dryer.
It's really the go to recommendation for me from now on.
I haven't dried a pillow yet - but it is surprisingly good at sensing, nothing so far has let me down particularly.
I tried the Wool cycle this week and was surprised it reverses every 5min as well.
Would have guessed more like a 10min period would make sense, but that works just fine.
Used it on an entrance matt and that dried just perfectly in the (obviously) timed 2:30h ish cycle.
I also used the Super 40 cycle today. It did leave the microfiber bath matts a bit damp-ish, but barely so. No reversing though.
That cycle also ramped up the compressor to full power and I think the fan as well.
It's surprisingly hard to make out if the fan is running at all, and even less so if the speed varies.
But the Wool and the Super 40 cycle did use a higher speed for the fan I think.
Overall, if there is any criticism at all, I would guess it would be that they could have done SO much more with the inverters for everything in there. Programming is kept surprisingly simple.
But it works, so.
The filter is really not up to par with ELux/AEGs filter design - that's just SO much easier to handle.
Here you have to take out both filters every time, some fluff gets stuck around the rim of the filter.
Then the fluff likes to stick to the filter because it's so loose.
It's a bit of a faff - but honestly not really much worse than a Beko or such.
Self cleaning so far I have only observed towards the end of the cycle.
I would have guessed it would run it before every drain? This dryer does not run the drain pump every few minutes, but only like 2 or 3 times tops throughout the cycle. But it doesn't, just at the end of most cycles, regardless of load size. Only the Wool cycle did not run self cleaning.
The last 10min on most cycles appear to be for cooling - and it usually skips right down to 5min, so barely ever a cool down.
Then it tumbles slowly, with the fan off. And then it does it's 2 self clean periods - I guess one for each half of the condenser?
Then a final drain.
That's one thing they could improve. As it tumbles really slowly for 5min in one direction and then ends the cycle laundry is somewhat more rolled up than it needs to be - it's not tangled or compacted, but a quick 30sec fast tumble in the opposite direction would be nice at the end.
It's hooked up to the drain, so can't really comment on the amount of lint other than the condenser looks like day one still.
On the topic of efficiency:
I guess we are getting to a kind of end game in dryer efficiency.
There are A-class dryers now that (from what I can tell) do not use anything special - naming the Arcelik design sold under Bauknecht that should be the cheapest A class dryer on the market right now.
But the big efficiency improvement here is the larger heat exchanger and the improved fluid dynamics.
It looks like such a slight difference, but if you look at the direction changes the air has to do when the heat exchanger is positioned off to the side compared to when it's centered, that is a significant difference.
That allows you to get more airflow with the same power - or the same airflow with less power.
I think what really pushed that move is the fact that normal condenser and vented machines are just EOL now, and you needed that offset design for normal condensers. But who ever haf that idea deserves a raise, really.
Add to that all motors now being synchronous motors, that's a big difference.
To put numbers to that: The good old ELux design from the 2000s had a 150W fan motor I think and a 100W-ish drum motor. That's 250W just for airflow and movement. This never uses more than 50% of that for the same thing.
And compressors do come in various efficiency classes as well - so these should be higher end versions.
I think we will probably see an A-10% and maybe an A-20% dryer in the coming years. But I do think manufacturers want their dryers to be somewhat reasonably fast as well, and this really doesn't take more than like 3h for even the fullest loads.
But then again: Back when A+++ was all the hype, we also needed 3h and inverter compressors back then.
I won't say we won't get to a point where A class is just like A+++ used to be towards the end.
