Simplicity SuperTwin ST5 W
same drain pump show picture (picture not from me) need gasket housing between motor, the shaft motor leak
Today y have used this washing machine for my laudry and work better of my Danby DTT420W noise spin is less.
If find spin motor mount and a good drain pump shaft seal, good for a long years ;)
Simp SuperTwin
Congrats on your latest find, buzywoman!
A great value washer, wish you hours and hours of laundry pleasure in the future
ps would be nice if you could post in here some photo(s) of your little treasure
Y have posted picture for you Unclejohn, my qc friend, sorry my android phone does'n have flash on kodak
search part spinner motor mount and drain pump or gasket inside housing between motor shaft and housing.
As the pump is electric you should be able to find a replacement one that fits your hoses. If you know of a shop that sells reconditioned appliances you could take in the pump and rubber mount to ask for replacements. The rubber mounts were used by various makes and I got some for a job only 2 or 3 years ago so hopefully you will find some. Replace the whole set, not just the broken one.
Hello fido, y have 5 spin motor mount and 1 of 4 broken but the washing machine avec a couple of years, and yes if find my idea is replace all 5 spin motor mount, aproximatively 2" long rubber to rubber end.
the electric drain pump housing have 4 bolts hole and 3 hose connect , this is 3/4 hose for 2 inlet and 1 outlet.
Congratulations
A very nice machine and a great find.
I hope you can get it repaired and working to your delight as it will make you very happy and washday soooo much fun!!!
hello ozzie908 , tank you for your ebay link is similae spin motor mount, but is to short , this is exactlty same of picture posted on upper reply.
check this link it's appear the same part. but i am in canada and the part is and britain.
trying find if not find in canada, usa or china before , if not find try order from britain, but shipping cost is more.
http://www.diytools.co.uk/spin-mount-rolls-colston.html
Tank you TwinTubber , I am very happy finding this twin tub is very quality compare at my china Danby DTT420W all in plastic and very cheap.
Busywoman
I may have some used ones I will find some and measure them.
Can you let me know what length the RUBBER part is not including the screw ?
Austin
Goog morning ozzie908, Y have measured on the washing machine with paper sheet and have aprox 50mm long and 20 mm round size
