Singer vintage ironer
I had a friend of mine hold onto this for me until I could pick it up in W.A., the guy who I brought it from and my friend picked it up, he said apparently it works but there’s no temperature control on the left side of the element, it would be nice to get this fully working and also to fix all that that little heated spot there, as it’s probably around a mid-size ironer as it’s a bit larger than a standard pillowcase
Off the bat would say 220v at 50hz tells one at least this ironer perhaps was made for European market. Is or was that voltage common in your neck of the woods.
Fact rating plate only states "Singer Trademark" not "made by" tells one at least this was a private label job.
To best of one's knowledge only thing Singer ever produced in house was sewing machines. Their steam presses, irons, etc... all were sourced from elsewhere.
Yeah, but it’s pretty unusual, as I’ve taken the base plate off and got some photos and the “footpedal“ has three switches in it, one when you just gently press on it, one directly after that, and then one when you put your foot down all the way
