cfz2882
-not quite sure if that year spread is exactly right,but the post-beam,wet cabinet solid tub hotpoints: pretty washers that seem to be virtually extinct today
Parents bought a MOL HG one new in 1970-large and pretty control panel and beautiful light blue spiral vane agitator.Washer was trouble free for about 9 years and then troubles began-first pump seal went,trouble to replace since bronze hub of plastic impeller secured to steel motor shaft with a setscrew and very stubborn to remove..a couple years later a friction pad came off the clutch-in 1981,all parts were NLA except pump kits,so obtained a ~ 1965 parts machine to provide clutch parts and other spares-it then went to the dump.The 1970 lasted a few more months until corroded aluminum "sediment tube"broke apart and lodged in the pump-parents then bought a new KM BD and hotpoint went to the dump where I watched it get buried in the landfill along with a white rollermatic-(rollermatics very common at the dump in the early 1980s BTW)Also had a ~1958 HP dryer for a few months~1980:bought at a yard sale,started to squeal then came to it's end with a loud clang as plastic drive roller shaft bushing wore out and hollow roller shaft wore through and drive pulley came off-dryer had lighted panel and as I recall a foot pedal to open door.Wish I could go back in time and grab both these as both would be an easy fix today
