Sorry for the long delay...here's how I created the WQ!
Sorry for the long delay--have had some work and family issues that have taken priority...I've been offline for a good while.
I wanted to wait until I could draw fancy pictures, but I simply don't have time.
1. I took a SQ flex agitator and "de-finned" it.--Removing the sides fins as well.
2. I chopped off the head of the agitator, JUST BELOW where the fabric softener dispenser holes are, but above the interior of where the agitator slips over the bell, or drive shaft--not sure what it's called.
3. At this point it was a gamble that the ramp agitator would even fit over my newly formed "washplate", but it did, with precision. I had previously held the bottoms of the two together to see if they were the same diameter.
4. I wanted the "washplate" style so that the agitator would match the SQ drive shaft/bell and I wouldn't have to worry about it.
5. Now, how to get the ramp agitator on the SQ. After making sure the ramp would "sit" on top of the SQ, Luckily, there were three mounting screws in the Westinghouse that held on a guide of sorts that apparently kept the agitator centered on the shaft/pole. I removed this and used the same three screws and screwed UP from the bottom of the SQ "washplate" into the ramp agitator. That alignment (with limited tools and assistance) was tricky.
6. I had to find away to keep the agitator cap on--this was a bit more tricky. I ended up drilling a hole in the SQ agitator in the areas that was left from the bell/drive areas and where the fabric softener area had ended. I then got a cut piece of metal (threaded, thank you Lowe's), that matched the thread of the original screw in the agitator cap, sent it up through the SQ and ramp agitator and screwed on the cap. This turned out to help snug everything up nicely.
I love this configuration--I can only do the equivilant to a medium SQ load since the agitator is smaller--for things like blankets. But if the load is big and has a lot of individual items (socks, shirts), she does a commanding job.
I expect it to eventually come apart from rusting of the parts, but for right now, I get a smile on my face every time I do a load of whites, low water, splashy action and the smell of original Tide in the air (detergents always smell better in hot water). It could be 1978 all over again.
Sorry if I rambled...ask any questions you would like...also taking requests for new videos.
Also, I did order the fabric softener dispenser--even in white it was really cool. Unfortunately, it kept unscrewing the agitator cap in the spin cycle. Not all the way--just enough to make it loose. Downey Ball to the rescue.
