Speed Queen AWN542 - washing new jeans
danmantn
Nov 3, 2009
982
Tennessee
Last year someone on here asked me to film the SQ washing jeans, and I did. However, the video was lost in the shuffle. I found the video on a data backup over the weekend and have published. Not sure who requested it, but here it is...in a belated sort of way. :) Enjoy!
Cool to see that the tub has indeed stopped indexing after the initial break-in. I never fully understood just how that works...
Apparently there is a "gel" or some substance that is on them when new--or so I'm told. It took me about 6 months to break it in (a couple of loads per week avg). My sister's washer (who has a big family) stopped after about a month.
Wash Tub Pitch
I had forgotten how the wash tub tends to pitch forward during agitation on these machines. Makes me wonder if the suspension springs might wear unevenly and benefit for rotation after 5000 miles...
Thanks for posting. A nice long video to satiate TL envy!
Malcolm
Thanks for sharing!
Im really impressed at the turnover for the jeans. That was one concern I had in considering the TL SQ over the FL. Great to be able to see the machine not only handle the washing aspect, but the balance and spin too! SQ ROCKS!
Dan (or anyone), I also posted a video of a Speed Queen washing jeans that you may perhaps be interested in seeing. Turnover isn't too impressive until you consider the fact that I actually had to stuff them down in a bit (but limited them to 9 pair). And they are pretty heavy duty. Probably would keep it limited to 8 pair in the future, since that seems to work very well, but may experiment again and try 10 someday.
I can tell ya 10 pairs of jeans ,depending on the size, mine are 34x32, stalls out the washer. 7 is the max I put in. 8 will give ok rollover but 9 slows it down to almost no rollover at all then there is extraction....my SQ washer takes forever to get up to top speed with a heavy load like that.
first of all great videos....as usual, great info
now a couple things I have come across as well....
as for the indexing.....mine has stopped, and I kind of miss it, the little increments seemed to help during the wash....
I also have a Raytheon model, the indexing tub helped with the rimflo filter ring, its movement helped scoop the lint into little piles, rather than just fill the holes, and filter action stopped......
also, over time, an annoying "squeek" developed from the brake, trying to hold the tub completely still......2 drops of 3n1 oil on the disc caused it to do a minimum index, and kill the noise....
one last thing, as Mike has pointed out, the spin on a large load did not seem to reach top speed for me as well......I stretched the spring about 1/2 inch more tighter, gave a better grip for wash and spin.....this slippage is similar to what I had with the Maytag's, but in this case a 3rd spring was added to correct the excess slippage....this may help you guys as well....
to a Maytag, theres slots to add another......
for the SQ.....I just pulled the spring about 1/2 inch tighter, and put a bend in it around the strap that holds it...you never actually remove it, just pull thru the hole and bend into place....it's a stiff wire, vice grips worked best to grab and bend....
tightening the spring on the Speed Queen
I'd be interested in doing that as well, since my Speed Queen isn't super speedy to get up to speed when the load isn't perfectly balanced. However, I would be concerned about doing incremental damage to the transmission over the long term. Any expert opinions on that?
