Speed Queen FL on EBAY!
Agreed
For me, buying a SQ/Huebsch wasn't about bling. I have to admit that having special cycles would be nice, what was paramount to me was reliability and serviceability, Like Mr. Mrb627 was saying.
The local appliance shop I bought it from mentioned that they service these exact kinds of washers in high use areas like Hotels, Inns and Condominium Common Areas. If it's designed for that, I wanted one. :) After all, between me and my wife, there's no way we're going to wear that machine out before I'm a senior citizen!
To answer TomTurbomatic's response...
I thought about buying a European Style Washer, but the only candidate for the job was the Asko Integrated series. (Known in Sweden as Cylinda) Mainly because it had a steel inner and outer tub. However, that proved to be a very expensive proposition, not to mention having an electrician wire up a separate 230 volt outlet. (Yes, they make a 60 hz model, I checked.) However, the 1.74 cu.ft tub really didn't appeal to me.
V-Zug machines are unheard of here in Canada. I think if they wanted to sell machines here, they'd have to sell a large range of models from the 1.75 cu.ft all the way up to massive 4.0 cu.ft machines to stay competitive. Especially with Meile already in the market here with 4.0 cu.ft machines!
If V-Zug made a machine for Canadians and was around 3.0-4.0 cu.ft, I would have considered it, but asking $4k Canadian is a bit much.
$1900 was nearly right at the top of my budget for a washer. Meile offered their 4.0 cu.ft machine at about $200 more, but I didn't see the value, especially considering theirs has what looks like a plastic outer tub. Unfortunately, I think I nearly caused a flamewar bringing that up. :-(
The Mieles I was discussing were my W1918 and W1986, both of which have double stainless tubs, are no longer in production, operate on 230 volts and offer wash temps from cold to 190F. The new Mieles with the plastic tubs are the larger ones that operate on 115 volts where the plastic outer tub performs an insulating function since it does not have 230 volt water heating capability, although my Creda which operates on 230 and will heat to 200F has a plastic outer tub and has proven very durable. As I said, the 230 volt Mieles are not mass market machines. My post was in response to the statement that the SQ was the finest domestic washer in the world. I realize the Zugs are not available here, but they are elsewhere and they are much more sophisticated machines than even the Mieles so I had to refute the statement that the SQ was the finest domestic washer in the world.
You bought a very good washer.
I think if you look at the very, very plain control panel and contrast it with the controls of other brands with displays and readouts, prompts, options and messages you will understand the lack of bling. I don't even think this machine has a bell, much less a whistle.
SQ Front Loaders = Laundromat/Commercial Washers
Once you wrap your head around that fact and act accordingly you'll understand SQ front loaders. If one can live with those limitations of design and or that is up your street, then have at it.
However as with laundromat washers you'll need a good supply of *HOT* water to reach the machine if that is the temp desired. Commercial laundries often have recirculation pumps on their hot water feed lines to keep things moving. Homeowners will probably have to resort to the old "dishwasher' trick of running a nearby tap to purge the line first.
