First time poster, long time reader here.
We have had a Whirlpool Duet washer and gas dryer, model GHW9200LW for 11 years. I am pretty sure we bought it pretty soon after they came out, since ours was made in Germany. The units have been great, with only very minor repairs. A drain pump in the washer and I think a temp sensor in the dryer, plus a single belt change. They have had very heavy use, washing almost daily for a family of 8. I shudder to think the number of loads done in the last 11 years, I would imagine in the range of 7-10,000. I know we do well over 12 loads a week.
But alas now the washer has a main bearing failure. Given the great history we have had with the units, I considered fixing it, but probably feel it is time to move on, given the age of these units. I do all the repairs myself, and the main bearing is one repair I wasn't looking forward to doing. It is still running, not leaking but making a horrible whine on the spin cycle.
I like to buy quality equipment, which has led me to Speed Queen. Other than SQ, I really haven't seen any great comments or reviews about any machine, at least no comments lauding their reliability. It seems that none of the current series has been around long enough to prove any sort of reliability. They sure don't show well, with a plethora of plastic, knobs, buttons and gimmicky settings. They look like throw a way units to me, which is actually pretty sad, considering most cost $1000 each.
So I am interested in the Speed Queen Imperial series, the stainless steel set. I am hoping someone can comment on a couple of questions I have.
1) Hot water boost. If I have read right, this is no longer available? Can it be added as an aftermarket piece? Is it available on the Huebsch units? I would really like to have this.
Are there any new units still in stock someplace that would have this?
2) Water levels. Can the Imperial Series FL units still be adjusted for the water level? I saw some posts, but am not 100% sure what models they refer to.
3) Is there any new units on the horizon, anything that I might be interested in? I hate to buy expensive equipment and then see an upgrade shortly after.
4) I will buy a gas dryer, due to the relatively cheap natural gas in our area. Are there any caveats or concerns with the SQ gas dryer? I think I read that it doesn't have a moisture sensor to sense drying? That is a shame, it seems like an simple way to test for moisture and gauge dryness and save energy. Our duet dryer had this and it worked relatively well.
Thank for any info you might have!
D
D
