nmassman44
The thing with top loaders that I have found is that one needs more detergent since the washer uses much more water for the wash solution than a front loader where there is less water and the detergent is much more concentrated to get the job done. I have had an SQ AWN311 top loader and will concur when I change the belt out that the outer tub is sporting rust at the weld joints now. I do not have this washer anymore since I gave it to friend of ours and he loves it. But this belt changing every 2 to 3 years is a tad much. I had a Maytag washer where the belts seemed to last forever…a real Maytag not these gawd awful Whirlpool built ones.
The Whirlpool 4516 washer I had when we moved here to FL I would not wish on anyone. I used the SuperWash cycle every time since it would fill the tub with water to the top and it was the most intense cycle to get clothes somewhat clean. I also had to use much more detergent and I had to get Calgon in use for every load since our water here is a tad hard.
SQ front loaders are not worth the $2k they command. Small wash drum, no water heater, they can keep it. I have an LG front loader that I love. It has the TurboWash system that I use every time. Nothing worse than hearing detergent land into the sump of the washer and not get into solution and then hear the detergent get dumped down the drain. There is a reason why LG is always rated well. Performance, capacity,reliability,heats water when needed and well made.
One thing I will have to add is that what one person experiences can be different from another and it does not invalidate their opinion. If one thinks something is a fact might not be a fact to someone else.
