dylanmitchell
Anyone have success with getting a SQ dryer moisture sensor cycle to work well? With Sensor Dry Near Dry equals still wet not damp or near dry and Dry equals scorched and overdried. I gave up on using the sensor setting shortly after I got the dryer figuring it just wasn't accurate and just used the manual time and temp setting. Recently, I figured I'd give it another try and it was the same. I think it's a known SQ dryer issue and SQ dryers are not know for being as great as the washers. I'm just curious if other folks do sensor or manual dry cycles.
I have a 2017 SQ ADGE9RGS gas dryer and don't think the sensor is broken or dirty just that it's how the SQ work from the factory. Overall, I'm happy enough with the dryer and it paris well with my AWNE92SP. I realy like actually I absolutely love the AWNE92SP so I'd make the same purchase over again since the washer is so good and I can get the performance I need out of the dryer with manual time and temp options. And the dryer has otherwise excellent performance and a powerful fan plus it's a SQ so easily repairable.
And FYI, these are 2017 models. It's unlikely I'd buy and 2018 or later SQ products unless I found a soft mount 20 or so pound commercial SQ FL that wasn't to beat up or too expensive.
