Reply #4
I think appliance manufacturers should give an option for mechanical controls or electronic controls to allow for options. There will be those who argue that electronic controls have no moving parts which means nothing will wear out which is true to a degree, but certain components on circuit boards degrade over time and eventually the machine will become junk if it were to sit for a few decades since the whole sequence of operations would come to a halt. Yes, mechanical timers can be a bit screwy if they were to sit for decades but usually can be taken apart for a cleaning and servicing perhaps a rebuild and you are back in business. Can’t really do that with electronic circuit boards that have been sitting for awhile unless you have a soldering iron and the electronic parts to fix the board.
The Maytag’s can have issues with balancing but since I always load my Maytags properly, I have never had balancing issues with them and there were a few times where the off balance sensor tripped but was on my behalf and not the machine’s.
The capacity is a bit smaller but if you look at some front loaders, the capacity is sort of the same since you are supposed to loosely load a front loader and not jam everything in. If you load a Maytag with 12 to 14 pounds of laundry then put the same load in a front loader, it would be about the same if that makes sense.
A redesign would be a bit of a gamble but if they were to make the Newton style of Maytag washers for home use and use their current design for commercial use, it would definitely allow them to compare both machines and if the Newton design had positive feedback from techs and customers, they would have a successful machine. That’s what Whirlpool did when they developed the direct drive washers, instead of designing a machine without doing any R&D, they designed them and sold them in small numbers and got feedback from tech and customers before phasing the belt drives out completely and that’s what Speed Queen would do if they were to use the Maytag Newton design.
