It is possible to get a "hot" wash with SQ or any other H-axis washer both domestic or otherwise. Same has was done in past and still may in some settings for all one knows.
Have hot water from taps between 160 and 180 degrees F. Using circulator will keep hot water moving in pipes so no flushing of cold water needed, soon as tap is open hot water comes out.
Pre-wash in warm (about 100F) water at hottest, then follow with wash using tap hot water as above. If water comes out at say 180F even accounting for hitting cold or warm wet wash and or cool machine you'll still get a wash temp of about 120 to 140 degrees F I shouldn't wonder.
Other way round is if it's hot water for bleaching or disinfecting one wants main hot wash is followed by another or even first rinse at same tap hot water temp (see above). By this time both machine and laundry in it are hot so there won't be much of a temperature drop. Rinses done in split (warm) water means machine won't cool down much so next cycles get a head start on temp by going into a washer what is already "heated" if you will.
Keeping boilers or other source of hot water at 140 or 180 degrees F obviously uses quite a lot of energy. So there's that to consider.
Up until say 1960's or maybe 1970's it wasn't uncommon in USA to find DHW that came out of heater at 180 degrees F (if not higher). Things were tempered down to 120-125 degrees F for safe use when bathing, lavatories, etc...., but washing machines, dishwashers and some other bits got full on hot water. This of course was when laundry was done in tubs, semi-automatic or even fully automatic washers that could handle such hot water temps. When soap was still queen of wash day one needed all that hot water for various reasons as well.
Today don't believe many have DWH above 120 F, though some do set their heaters (if possible) to 140F.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44274_46
