99% done
My hands were greasy and cold, so I wasn't in a picture taking mood often, but the boot replacement went well. This pic sucks, but I scraped gunk off the shaft, vacuumed up all the crud that fell on the assembly below, screwed the new boot on with the old bands, then used some clear RTV sealant on both the top and bottom of the boot.
On the inside of the cabinet, I scraped and Rustoleum'd the minor rust, and on the back of the cabinet and the worst spots of the base, without major dissasembly. The pump and all 3 belts and inlet hoses and water valve all lookk like they were replaced withing the last six months, so I did nothing to them. I got a few drops of oil into the top of the motor's top bearing, and some on the various sparkling clean agi shaft and various clean and oily assemblies between the tranny and the center shaft. I do not know what the parts are, some fulcrum item that pops the tranny out of agitation?
The exterior has minor surface rust near the base, at the screw holes, and I can't imagine finding the right paint cclor, so I sanded lightly then used Rustoleum Clear Epoxy. I bought the wrong size stainless steel screws, but will buy the right ones tomorrow. I think it will look better than the day it came home, and will be proected better than before.
I bought Perma-Tex Blue epoxy gasket maker for the tub gasket rim, where the outer tub hits the machine top, but so far I've done 3 loads with the rear and front removed for excellent visual inspection, and no leaks. I never opened the blue epoxy. I'll wait maybe 3 more loads of clothes and constantly inspect with a flashlight, from front and back. You can see an amazing amount of the gasket with all that open area. If everything stays dry, I won't do the extra epoxy and just consider myself lucky.
