Speed Queen Topload Washer noisy wash cycle
raqune
Aug 23, 2024
0
USA
Looking to buy a used Speed Queen washing machine that is described as "just a little loud", when I asked seller when its noisy he said during wash cycle and his research tells him it's "just 2 metal pieces rubbing together" and it works fine. I'm used to fixing things and the price is reasonable so I'm going to go see it and wanted to know what I should look for to determine what type of repairs I might be facing. Would really appreciate any direction form other members with experience on these things. It is a model AWN432SP113TW04
There's also a fix to a similar noise that involves applying grease to the washers between the driven sprocket and the brake area.
Both noises are easily remedied.
You'll enjoy the 432 over newer post 2017 models as yours has a mechanical timer that YOU have full control over the cycles and times, full control over the water level, and a fast spin during the spray rinse.
