Speed Queen washer leaking and making noise
flsq
Member
Jan 24, 2024
20
Florida
Model AWN63RSN115TW01
This is in regard to an add in FB, "Worked perfectly until yesterday. Then started leaking and making a noise."
They are selling it for $100, looks to be in great condition, any idea what the issue could be? What to look for if I go to check it out?
How does it sound? Does it do it during agitation or spin?
I'm gonna ask some more questions to try and get a better idea, he says it was made in 2019, so not super old but not all that new either
"not a grinding sound, during washing, the load had just started. It was a set of sheets, so not a heavy load. The leak was coming from underneath, steady leak."
So doesn't sound like a pump issue unfortunately haha. Maybe a leak between the tub and trans?
With any luck, it has a split hose or something simple like that... I've read the seal replacement job is a real bear, depending on how corroded stuff is once you get into it, plus I think the seal kit is around $150.
