Speed Queen Washers (current models)
Dryer Repaired
Well, at 8:45 last night, my dryer was restored to working order. Took several hours to get there though.
We replaced the motor and the timer and still, the dryer would stop running when the start button was released. The tech and I pulled out the wiring schematic and went through several components making sure all thermostats and relays were in the normally open or closed positions. Then, we started checking wires and found a badly crimped with on the back of the timer. By this time, it was just after 8 o'clock last night. The tech rummaged through his tool box and found a piece of wire with a crimped spade on the end of it. He spliced into the bad wire and WALLAH! Dryer operation restored.
The tech will return next week to replace the patch job repair with a proper connector. But at least I have the dryer back in operation.
Thank God!
Malcolm
