Speed Queen wringer washer parts
abcomatic
Feb 16, 2006
2,138
Bradford, Illinois
HI everyone, where would I be able to find Speed Queen wringer washer parts?  I need a seal or gasket that is attached to the drain under the tub. It is held to the machine with a screw type clamp that clamps the bottom part of the drain to the top part.  Thanks so much. The washer is in great shape, but I need the gasket so that it won't leak.  Thanks for your help, Gary
My machine is exactly the same one in the picture.  The drain is in two pieces, the bottom part fits into the top part that we see in the picture. There is a gasket between the two and that is the gasket that I need. My quess is that if the pump won't work all of a sudden, the wire that is attached to the knob needs to be tightened and then it will pull the wheel against the belt. Thanks, Gary
John, thanks for your help on this.  When I apply the marine sealant, do I put it in the inside of the rim of the drain section or just on the outside? Thanks once again. Gary
John, thanks for your help on this.  When I apply the marine sealant, do I put it in the inside of the rim, where the round seal was of the drain section or just on the outside? Thanks once again. Gary
