jocks54
Hmmmmm.......Is it possible the dryer vent is to long???
We have a rigid pipe with 2 elbows, It is long but it sure blows a good amount out of the vent. The appliance tech suggested it may be to long. He did test the solenoids. And said they were ok. My problem is I do not want the dryer to vent into the crawl space under the home. Trust me when I say there is no way to shorten it except allowing it to blow into the crawl space.
I do use the time dry cycle. I have found the auto dry cycle leaves everything damp at the end of the cycle. Maybe I will crawl under and shorten the hose temporarily to see if it helps.
