Which manufacturers make non-aluminum (or coated aluminum) s
I thought someone posted here a month or so ago that Miele or Electrolux use stainless steel spiders. Does anyone know for sure? I agree, coating an aluminum spider with a protective layer would solve the corrosion problem, or just make it out of something more durable like steel or iron, even if it raises the cost of the machine.
What I can't stand to see is a machine in perfect working order, except the spider, being tossed out into a landfill and not recycled. When the motor wears out, it wears out, but it seems as if the majority of FL washers that are put out to pasture involve spider failures.
One thing is certain: before I bought my next FL, I would call the manufacturer and ask to speak to a product specialist and inquire about the spider. If aluminum, I'd avoid the product. I have a great Frigidaire 2140 that has given four years flawless service, but I know one day I will hear the clanging sound that comes from a broken spider. For that reason, I keep up on the latest models so that, if necessary to replace the current washer, I have already done my research BEFORE it's time to replace the washer.
