spin dryers thread
aquarius8000
Mar 21, 2011
1,537
Hi, I decided to create a thread on spin dryers. This first one is my Grans. Again I would like to know when the dryers shown were made.
Christopher
1965? creda spinner
This is my spinner. It was my great Grandad's wich acompanied with a hoover like my toy one. It spins at 2800rpm.
Made in UK
I don"t know for yours, but on the first pic, I can clearly see that it says Made in UK (under CREDA written) ;)
Have A "Paki" Spin Drier
From Laundry Alternative, and have to say it gets the job done.
Spins at 3200 rpms which is faster than most older Euro versions (1500 or about 2500 respectively), though because it is mainly plastic makes a heck of a racket if not loaded totally balanced.
Am not sure if the increase in speed is due to a Euro 50hz motor being run on USA's 60hz. Know several companies still make spin dryers for sale in the EU, but don't think the market is that great to warrant special versions just for the USA market.
Have always toyed with the idea of having a Euro spin dryer sent over, especially one of those *huge* Frigidare models that hold about 7kg (versus the 4-6 kilo normal capacity), but again not sure what the change in frequency would do to the motor.
The older spin dryer offerings from say Miele, AEG and the like whilst built rock solid, tend to spin at lower rpms than modern versions. This is at least what I've seen scouting around eBay.de.
Oh another thing:
My modern Paki spinner slowly revs up to full power, instead of the older method of just starting out at the max. This tends to allow for better distribution of a load and less "whacking" noise as things aren't violently thrown to the side.
Take A Tip From Me
Rather from a vintage commercial laundry manual I've got.
When loading extractors without a center cone (Easy Spin drier's and others including many commercial units have a center post), use one's arm or something to help in loading items *around* the sides of the basket. When properly loaded one should always be able to see and reach down the center of any load in a spin drier's basket.
Rationale for above?
Unlike a top loading washing machine with center post, or a H-Axis washer that will distribute a wash load before spinning (or at least attempt to), if you load items into a spin dryer Willy-Nilly they will get wacked to the sides as the unit powers up. This not only causes out of balance loads (and all the noise and vibrations that go with), it is hard on textiles and won't do the machine any good either.
One more tip:
If you've lost or damaged the plastic/rubber mat that comes with the spin dryer, and is supposed to sit on top of a load during the extracton process, all is not lost. After the mandatory packing down of the load simply place a heavy towel or bit of flannel over the load, and again pack it down making sure it does not reach up/over the top of the spin basket. This will do the same as the spin mat. Indeed large commercial extractors such as those made by Bock don't come with a mat, but operators would place a heavy towel or something across the top of the load instead.
Mind you, if you load the machine properly, and the load barely reaches half or less way up the basket after being pushed down, you probably can dispense with using a mat or anything else. The only reason for using these things is to prevent either small items from being flung up and over the tub, and or items on top from excessive friction caused by being rubbed against the spin lid.
Small items should always be loaded at the bottom of a load, covered by larger things. Loads should never extend very close to the top of the extractor basket anyway. Better to do smaller batches than risk "spin burn" to an item.
My spin dryer . . .
. . . is a SpinX I ordered from a company in Houston, TX. I love it. I'm not sure how fast it spins, but the figure 2400 rpm sticks in my mind.
It really saves a lot of drying time, especially blue jeans, whether hanging on the line outside or using a gas or electric dryer.
I guess I've had mine for at least 30 years by now.
Jerry Gay
@mattewza
That's easy to answer.
washing machines have a wider drum so first of all they don't need such high speed to get the same result.
It's also not safe to have a huge drum spinning at this speed.
Front loaders can use the gravity to try to balance the load perfectly, by spinning the drum at low speed and increase it gradually until the load is fully balanced and even on front loaders, the spin speed doesn't have to be so fast to get the same result because the drum is wider. 2800 or 3200 RPM in a front loader is not only dangerous to the machine and the ambient around it but would also be harmful to the clothes as incrediblý smashing forces would deform the fabrics.
Being As That May
There has to be a middle ground between sopping wet laundry that comes out of most "laundromat" front loaders, and safety/machine damage, etc.
IMHO the bit about larger radius drums removing more water due to their size is a load of flannel. Well perhaps if the final spin speeds were goosed up a bit, but am here to tell you that laundry done in any of the SQ front loaders at our local emerge not far from dripping wet. If one tried could easily wring water out of most loads. Indeed items taken home right from the washer and bunged into either the Hoover or "Paki" spin dryer will give nearly a quart or more of water.
Laundromat machines are made to be profitable. it doesn't count.
of course there's an equation to be respected about spin speed and drum size to get the same result. my Frigidaire Affinity washer spins at 1100 RPM and my Wanke spin dryer spins at 2800. Believe it of not, the Frigidaire spins better.
If laundromat machines spin fast, the load will dry in only one dryer cycle. Why do that if we can simply force the consumer to use more dryer cycles (and pay more)? Most of the laundromat machines that can be programed by the laundromat owner, are always set to the minimum spin speed possible.
If a laundromat charge the dryer by load (no matter about the time), they would be desperate to find a machine that spins at a 1000000000000RPM
Laundress:
I didn't know you had one of the Paki spinners. I think the ones we have are the only ones left. We haven't used ours in quite some time due to the noise it makes.
But it still worked and hasn't exploded on us yet!
@whirlcool
Yes,nabbed one from fleaBay last year that was "little" used so said the seller.
There is version being sold currently, saw it on eBay last week.
Once the extractor gets up and running it is actually supposed to be quite quiet. However as noted above if the load is out of balance and or the spinner is not loaded properly it will make a god awful racket. Methinks much of the noise comes from the plastic inner parts banging all over the place. Try loading as per my instructions above and see where that gets you.
Creda spin dryer
Hi Aquarius8000 and all.Im glad you started this thread as i have alwaya been intrested in spin dryers,especialy the older ones and not the newer chinese plastic ones.I think they became popular in the u.k. in the late 50s-early 60s as people bought them to go with there wringer washers.As at that time twin tub washers had just become available but not many u.k. kitchens had the space,whereas a compact wringer washer,which they already had ,and a seperate spinner could be kept elsewhere.As a child i remember 2 close neighbours having just that combination,next door had a Hotpoint Princess and a Creda spinner and the neighbour opposite had a Servis powerglide and a Creda spinner ,the same model as yours.Now i think just elderly people buy them for drying a few hand washed things.This is my favourite spinner and it makes a lovely growl when it starts.Its a Creda 704MK2 pobably late 60s with a beautiful torquoise blue spin can/basket.A bit rare to find a good one as they had problems with the paint flaking of the spin can/basket.Regards Nige.
Modern day favourite
Zannusi sd2822w,
I think this was the last decent spinner available in the u.k. Galvanised steel painted body,stainless steel drum.Drain pump.Made in Germany.Currently available Hotpoint/Creda spinners come from some former eastern bloc country and rust away rapidly.
Spin Dryers
Love this thread. I have 2 spin dryers, an old creda and miele. Both spin at 2800rpm, makes a big difference when using a tumble dryer.
Also, a good friend of mine just lost his job. He bought a hotpoint tumble dryer at xmas. He asked me if I wanted to buy it off him as he can not afford to use it. Its a hotpoint aquarius model tvm 570 and takes 7kg. I noticed on the rating plate it says, made in the UK. I thought all hotpoint appliances where made in Italy.
Paul
