My Whirlpool convertible/portable (in Harvest Gold no less) had spray rinses after main wash before rinse, and after during first few minutes of final spin.
To get an idea behind why washing machines use spin rinses you can study patents.
https://patents.google.com/patent/US5737790A/en
https://patents.google.com/patent/US5167722A/en
https://www.freepatentsonline.com/5167722.html
IIRC original purpose of spin rinses was to reduce water used for rinsing.
Many older automatic washing machines had either overflow rinsing and or ability to do two deep rinses.
Spray rinses after deep before final spin removes (again in theory) need for a second full rinse.
Easy "SpinDrier" washers and others also realized it was possible to rinse laundry using less water just doing spray rinses. Hoover and other twin tubs also had these methods. Unimac twin tub washers still use a method similar to Easy spin drier washers of old.
To effectively spray rinse water must be aimed properly at washing, tub rotation must be at speeds that water merely will not just bounce off laundry, but rather be allowed to saturate by penetration.
Overflow rinsing was important in days when soap was still queen of wash day as gunk and scum was floated up and over wash. This instead of laundry acting as a filter when water was drained through.
With semi-automatic washers such as wringers or twin tubs one lifts laundry out of wash water into a mangle or spin dryer. Link and gunk tend to cling less to laundry that is lifted out of dirty water.
Spray rinsing will accomplish (or so it is hoped) same results as overflow rinsing. Water sprayed at wash will saturate laundry and centrifugal force will take water along with dissolved soils, gunk, scum and lint out and down drain.
Spray rinsing also (again hopefully) will clear much or most of soap/detergent/suds from outer wash tub and sump. When washer stops extraction cycle and begins to fill with water for rinse cycle it should be mostly clean. This rather than regurgitating whatever was left after wash.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?76135
