Spray Bottles That Won't Fail?
mark_wpduet
Dec 29, 2008
2,662
Lexington KY
I'm so sick of buying new spray bottles. I use distilled water and a little bleach and fill them up and that's what I use to spray things down with when I clean, but they only last a few months if I'm lucky...I see there are professional spray bottles but does anyone know of the best ones and where should I buy them. Thanks
MY TRICK ;)
I've had problems also with the trigger not rebounding and just not spraying well. I did get mine at a industrial supply but seems like the same cheap quality, I just use it for water but they would always die before I tried this. If the rubber isn't cracked this should work, best to start with a new sprayer I think. What works is a good quality silicone spray lube. With sprayer upside down spray a bit in the round plunger area and squeese trigger a several times to work it in, wipe with paper towel. On your first application might have to spray a second time. I use my sprayer several times a week and lasts 1-3 months till it needs another spray of silicone, don't flood it and waste the silicone, doesn't take too much after the first time. My current sprayer has lasted well over 6 months now but as soon as it misses a beat I give it a spray of silicone and keeps on spraying like new.
