JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
I couldn't get over how cool they looked. I had folks over on Monday night for a gathering. Most could care less about vintage appliances, but even these appliance non-lovers thought the Ladies were stunning.
Washer panel lit.
Dryer panel lit.
Close up of the buttons. One of a few issues with the washer is the buttons, which can be an issue for these 59/60 push button Kenmores. The colors have faded/changed over time, and the writing can rub away with a careless hand armed with the wrong wash cloth.
Either way, I'm still happy.
Dryer panel buttons.
Washer money shot. There's some work to be done here!
Dryer money shot. I just LOVE porcelain dryer drums.
Close up of the rarely seen '59 Lady K Self Cleaning recirculating filter dispenser.
Model tags for both machines. Can anyone date these - or does that apply to a later serial production year?
Washer shot - under the hood. Some normal stuff here, but a few odd ball things as well.
First off, and it is hard to see in this photo, but here is the dispenser outlet for the softener, with a hole cut out on the snubber ring top!
If I had not noticed this label on the right hand side of the cabinet, I wouldn't have paid much attention to the bulb...
I've never seen a ballast duty bulb before! Very cool.
Thermostatic, three temp water valve
And, last but not least, the end of cycle chime!
Here's something you don't see everyday - a belt drive with the service panel still in place!
Ok - I've moved around, lifted, and hauled a ton of belt drives. This is, by far, the HEAVIEST one I've never encountered.
Gotta love an ALL PORCELAIN cabinet!
Washer wiring diagram. The dryer's wiring diagram is MIA.
NSFW
Who doesn't appreciate a shot underneath a Lady's skirt?
Ok, I've got to be honest. I was expecting the worst. I really was. But when I saw how clean everything was on the bottom side, I couldn't believe it!
Notice check valve number 1 where we normally see the '60 and later sump.
Also, they got away with a 2 port pump on this ultra-crazy machine. Amazing!
AND, AND....
The famous marble self cleaning lint filter!
Last, but not least, the second check valve, on the left hand side of the outer tub.
So, ok, enough with the washer. How about the dryer?
Dire warning label!
Top revealed on the dryer.
(the clips aren't missing, they just fell off when the top was lifted.)
Dryer, back shot. Wiring diagram MIA.
Not surprising, but this dryer saw some service!
Dryer burner assembly. Yes, that is correct. 37,000 BTU.
Honestly, the dryer was pretty clean inside. We've all seen much worse.
Lint bag. Or what's left of it.
Amended instruction. "Vacuum sweeper"
Sponsored
