The Maytag's we used in Hawaii last year, had the option of an eco wash/rinse or by using the Heavy Duty cycle with Fabric softener option you got a full tub of water (That seemed hot) and an agitator, these machines seemed pretty new, so I would say that Whirlpool are still offering the same options.
Rapunzel, the 1970's FL's used about 120L of water, not 180L like a TL machine. (the FL washed 4.5K, the TL 5-6kg) My W423 is 123L per cycle with Pre-wash for a total of 7 water changes. That works out to 17L per fill, rather than 90L. Because the Miele back then also heated the prewash, it meant you were only heating 34L of water, not 90L for a hot wash. It doesn't rinse any better than the new machines because it only spins after 2 of the water changes and then after the final rinse.
I have a mix of Old and new TL and Old and new FL machines, we run 5 Miele front loaders between 3 houses, 4 of which are between 5-10 years old and use 50-60L of water per cycle. I get that in the USA with only 110v you cant easily get a FL that performs like a euro one, but with 240v, you put the clothes in, add a good quality detergent, pick the right temperature and then 40 mins to 2 hours later clothes are clean and stain free.
I grew up with TL machines and the experience I have when I use them now, is the same as I remember with Mum as a kid. You soak whites overnight in a bucket, you need to use Preen/Spray and Wash on stains, collars, etc to get the grime out, and then you add a scoop of Oxygen bleach with the detergent. If you do all of that, then you get clean clothes.
I agree with some of the above points
1) HE Toploaders aren't the best of ideas, clothes need to tumble or flex, not be held against a fast spinning plate, or dragged around by and agitator in no water, if you're going HE, go FL.
2) FL that cant heat the water to an appropriate temperature, wont perform as well as those that do (110v vs 240v)
But I disagree with the following
1) All HE machines aren't bad, in just the same way that all traditional TL machines aren't good. The 60 or 90 second rinse in the Ax12 series maytags is a case in point
2) When you're washing clothes, the focus isn't just on saving the water, its also about not spending money on the energy needed to heat it. If you're only heating 10-15L of water, that's less than 20% of the cost of heating the water for a Traditional TL machine.
Everyone has passionate feeling about this, But brands other than Speed Queen still make machines with Traditional deep fill capabilities and HE doesnt have to equal bad.
Regards
Nathan
Regards
Nathan
