AM DXing
yes,used to do lots of AM(and shortwave) dxing-especially around 1981-'85,but still
do it on occaision today.Around 1997-98 i used to enjoy listening to
"coast to coast AM"usually via AM 1500 minneapolis using the '62 S/C tuner
amped with a '69 14w mono heathkit amp($10 yard sale buy,was well assembled)
Since program ran later than i wanted stay up for-till around 4:00 am,i rigged up
a reel to reel recorder('69 VM built GE),set the recorder with power off and
triggered the setup to come on with a timer-worked great most of the time-
would rewind tape and play the next day.Running the recorder on lowest speed
with a 2400'tape would usually record most of the program,but i forget the exact
run time-later found out some people were doing the same thing using a VCR in"ELP"
mode to record just the sound...
In the '81-85 years liked to use old car radios for my AM DXing-a favorite was a
1958 chevy radio-still partway tube with transistor audio amp and no vibrator.
I still have the VM turntable from the school PA system-looked like it had little
use and one day i may convert it to stereo and use it as it is quite nice with it's
big 4-pole motor-not sure if the motor has the permanent magnet ring above the
induction motor section of the motor's rotor to make it "lock onto"line frequency
and run sychronus-my "daily driver"Dual turntable has this style of motor.
