Stubborn Maytag 142
Nothing more frustrating than to have a goal in mind, and a mental time-frame of when you want to finnish the job----------and the damn machine won't cooperate! Yeah, the dremel was likely less impact than a sledge hammer, but after all that hassle, a sledge hammer is better at stress relief!
I have always associated the worn down white procelain on the 'tags tubs with years of heavy use------not years of overloading. I suppose it could be some of both. Lots of jeans, overalls, etc. with stiff fabrics and heavy metal buttons and zippers to scrape along the tub as they make the turn and start their way back up from the bottom of the tub. These machines in "farm" service will really show some wear!
My older 'tags (early sixties type Highlanders) with either the solid center-post or filter type center-post agitators ALL have great roll-over. It is fun to watch the action with three or four pair of stiff new jeans comprising the load. LOTS of splashy action! Like most machines, I guess it just depends on how you load them, I have a pretty good eye for what looks just right for a load in these old machines. One wash cloth too many and the roll-over stops-----but that can also be said of many other machines when overloaded.
Hope you guys are having fun and look forward to seeing the 142 up and running with the "new" tub------mission accomplished!
Greg and Gary:
Been there, done that so many times. It is a blast taking those machines apart. I am always amazed at how different each and every Maytag restoration is, even though it could be an exact repeat.
Thanks for the Dremel advise, I do have one, but always chose the hard way I guess. NOT ANY LONGER!
Austin - you are truly an agitator with your agitators.
Steve
As we say in Armenian: "Aferim"!!! (Combine "Bravo" and "Mazel-Tov"! and you get the idea).
What a freakin' gorgeous machine! And it even has my beloved Maytag timed bleach dispenser. Would an A206 agitator fit on that drive post? (only half-serious).
oh - should know better than to just believe one picture
Ok, you pulled my leg on that one. Brief pause here, while I screw it back in.
Looks great - and I am very impressed by the JB-Weld patch. How'd ya get it so smooth?
Wow what a difference you guys! The "new" 142 looks like new! Does the Speed Queen filter reach down and grab water from the Maytag?
My name is SpeedqueenGKC and I WANT THAT FILTER!!!
That Maytag looks BEAUTIFUL now--new for 1958!! I bet both you and Don are really impressed about how it turned out; I know I am!!! Definitely something to be proud of!!
And that SQ filter/dispenser is just HUGE...almost swallows up all the space in that tub! At first glance I thought it was a GE Mini-Basket. Could I buy it from you? ;-)
*Ducks and runs*
--Austin
Now that's what I'm talking about! One fantastic resto, done! Don, you have a beautiful machine there, you should be very proud of it. The hard work you two put into it seems to have really paid off big time. On the re-assembly, did you use brand new parts (tub seal, etc?)
Hard to believe that washers were once beautiful. They don't get much better than this ;-)
Ben
Great job you guys! That machine looks like it just rolled off the assembly line! The older style Maytag center timer machines always steal the show
Congratulations!
