Hello again. After a few days of rest, I picked up the towel again. Finally got both tubs all cleaned and went on to clean and re-greased the motor glides. The transmission pulley was covered with greased on linty gunk that looked like cat fur. Removed the pulley and cleaned it.
Does the center in the transmission pulley need to be re-greased? If so, what kind of grease and how much to put on?
Locally I can't find Zoom Spout oil to lube the pump. Would the blue label 3-IN-1 SAE 20 motor oil be ok/safe to use?
http://www.3inone.com/products/motor-oil/
Do the motor and pump pulleys need to be lubed?
