Stupid jetsystem!
Timon90,
Am I correct in thinking the WH2900 was a Jetsystem model? I love the way the machine is switched on using the temperature dial.
The most sophisticated black door model sold in the UK was the WH2125 Jetsystem, there being no actual Zanussi equivalent! Of course the king of all black door Electroluxes was the WD3000T washer dryer.
I nearly bought a WH818, but it was a long way to fetch it and really I want one of the more advanced Jetsystem machines.
Tom
Think it inspired anything else??
I wonder if it inspired the Indesit Moon designers ?
My grandmother had the machine pictured in the post above (Black door Electrolux) it lasted years!
Were they all JetSystem ?
I think you pulled out the programme selection knob to start them, not the temp knob.
Many washers in the 1970s / 80s used that method of starting.
I had a WH3000T before, but the timer was bad, and I throwed the machine away. I've realized now that I should have saved the motor from that, and used this on the WH2900. The bearings in the WH2900motor is making some noise, and is not to get as a sparepart anymore.
Spin Washing
When the JetSystem first appeared it was quite a revolution, no other manufacturer could reduce the consumption of water to the same level at the time....
The Spin Wash was introduced following a lot of research about Laundry Methods and best practice for best results....one of the key elements for introducing it was the reliability and effect of spinning soapy water out of clothes like TwinTubs etc....
Think about it four mins of washtime, then spin all that hot soapy water out of the clothes!!!, that action probably moved any stains etc that the previous washtime did not...
I do like the AEG with Directa Jet, never had any complaints about them blocking though!!!as with anything a lot of components are just reduced down in cost now until they fail and are thrown/replaced...
mrx
On most of the WH series you did indeed pull the programmer knob out to start the machine. However, on the WH2125 and the WD3000T (including Timons WH2900 which was never available here) you *turned* the temperature dial clockwise from '0' to your selected temperature to switch the machine on.
I forgot to mention...
Only the high end models had Jetsystem (if it did spins in the wash it would have Jetsystem), the basic models such as the WH818 had an induction motor and very similar timer to my Z9191T.
Tom
Pic of my 2002 AEG Lavamat 72640 with Spin Rinse Water Jet
Not got the nice LOCD as the above but its a pretty reliable machine.
I had an AEG 86741, didn't have any problems at all with the jet! Always was nice and thick and soaked the load down pretty well. Although the 86741 wasn't that water stingy, always used a decent level as well as the recirculation pump, lowest level was where water was in the door seal touching the rim of the drum. My grandparents have the machine now and it's still running strong jet intact and everything, as far as I was aware the same pump is used for recirculating the water as is draining the water out so nothing should really become stuck in the jet as water goes through the pump filter first.
Jon
lavamat jon
That's true its the same pump that drains out the water that pumps the water through the drum, so it is constantly in use. Mine has never been a problem, just is a bit on noisy side when the jet is on.
Hair clips, coins are normally held in the door seal but if any makes into the drian pump it is captured by the filter.
I love those Zanussi/AEG/Electrolux Jetsystem washing machines, I think they're just great! I reckon Zanussi was ahead of it's game when it first came out and having a great way of using less water, energy and detergent. It's a good thing it caught on with other brands lol!
The first time I observed a Jetsystem in action was at my old school, they had a late 1998 WJS1397W Washer-Dryer in a medium-sized kitchen and I found it really good fun to watch.
The Jetsystem gave the effect that it was constantly filling with water when it wasn't. But of course, the recirculation pump was doing the work.
I've noticed that it got quite sudsy during the wash too, Biological Ariel Powder was the only thing used in it and the water from the recirculation pump was made responsible for this and often caused sudslocks on wash-spins lol! But it managed to clear out the suds during the rinsing.
In fact it's so good, I wouldn't mind owing one of these myself! They're not all bad you know, especially the washing action on early models. I'd love to see that in action one day!
Long the Jetsystem may continue for many years to come!
Here's a pic of the machine, it's not the best quality pic but at least it was a good machine.
You know what, I think I'm slowly falling in love with Lavamat Jon on here, he's one of the nicest people I've ever met online and on here of course!
Could this be love on the Washer Forum? Lets hope so lol!
Wash-spins...
...Funny you should say that, as my Grandfather had a Zanussi machine from 1999, and I was almost certain that it did that.
However, my Zanussi IZ16 from 2001 does not. It does rinse-spins instead.
I wonder if they discovered a problem with wash-spins?
As for sudslock, I always got the impression (and still do) that the laundry detergents were far too foamy. Shouldn't they be as non-foamy as dishwasher detergent? Maybe simple washing soda is the answer.
