stricklybojack
Ad copy:
Brand new Replacement Evaporators for the most common models of Subzero Refrigerators, available now!
We started manufacturing Evaporators for the Most Common Models of Subzero Refrigerators, due to the fact Subzero pulled all their parts from being accessible to service companies and customers.
These Brand New Evaporators have also been redesigned, due to an inherent problem Subzero has had for many years, leaking!
They were apparently using the wrong grade and type of tubing, which would oxidize and cause pin hole leaks, so we are making them now with the Highest Grade of Refrigeration aluminum available, to stop this leaking issues, and provide a higher quality product, evaporator, to the Subzero service company or customer.
Check out our web site to see if your Model evaporator is available, and if not, let us know what model you have and we will work to make sure that we address that model in the near future.
We have 6 Models of evaporators available now, the Most Common Models, which you can purchase at: http://www.szpartz.com
We also have Subzero replacement evaporators and other parts for Subzero!
Check us out today!
Thxx, Mike
The evaporators we are currently manufacturing, are listed in order, as they are in the pics, from left to right:
SubZero Part#'s:
3130280(4204440)
4204400
4204410
4204420
4204430
7014701
Model Relation to SZPartz.com Part#'s:
Model: 501R - Part#7014701PR
Model: 561, 427, 430 - Part#3130280PR(4204440PR)
Model: 550, 560 - Part#4204400PR
Model: 501R, 601R - Part#4204410PR
Model: 511, 532, 590, 611, 632, 690, 695-2 - Part#4204420PR
Model: 542, 580, 642, 680 - Part#4204430PR
Ad copy:
Check us out today!
Thxx, Mike
SubZero Part#'s:
3130280(4204440)
4204400
4204410
4204420
4204430
7014701
