The beautiful 906!
This is the set I found at my local Launderall dealer, Coffman Appliance, now long gone. They were in the shop window for couple of months and I finally stopped in and looked at them. Once I saw how nice they were, they had to come home. Fred now has them in Chicago. (this was also my laundry room in '00, things look quite different today!)
Since this set, I've never been without a Maytag pushbutton washer. I prefer the older models, but I have enough parts to make another set of '06 series if I ever get the urge.
Maytag actually changed these machines quite often during their production from the first A900, the A902 and then into the 906's. They did various different things with the off-balance load handling, including one disaster with cork dampers on the underside of the baseplate that the brake package would rub against to slow down the spin. That didn't last long, in use or in production.
The A900 through the first series of 906 washers had fairly complicated control system, a series of switches and motor attached to a rotisserie gearing advanced the timer when you made a selection. The two water levels are controlled with a solenoid lever to switch between them. Post 1969 906 washers used a more compact rapid-advance timer with the advance motor built in, much like a KDS-xx dishwasher and used two pressure switches for water level.
You can easily adjust the cycles - if you want a partial load fill of cold water, press the Bright Colors button, wait for the tub to fill to proper level and then push the partial load colors button. If you want to be a "dial pusher" you can cut short any washtime by pushing Spin to empty the tub and spin the load (no spray rinse) then the Rinse-Spin button, Want an extra warm rinse? Push the full or partial colors button, when the tub fills just push rinse-spin and you're back to automatic washday ease. LOL
These washers were a great example of engineers and designers dreaming up solutions for a problem that never existed. Most homemakers didn't find operating a washing machine terribly stressful or complicated.
