Steve
Thanks for your input. I really believe that the lens cover was covering the drain hole during the spray rinse and not letting the water drain out. When the spray rinse ended, I heard something clanging around in the tub which had to be that darn lens cover.
The issue with the machine now is getting the outer tubs back together. When Steve and I put the rubber gasket back on the machine and tightened the metal retainer ring, we had some leaking issue. I have ordered a new rubber gasket tub ring and hopefully, this will solve the leaking problem during spin. I have been advised to put WD 40 on the rubber ring. Someoene also suggested rubber silicone. Any suggestions for putting the two outer tubs back together to prevent leaking?
Something strange happened yesterday during the start of spin. The motor hesitated a bit, then went into the spin cycle. I was told that a possible contact was sticking and to give it a light spray of WD 40. What are your thoughts on this?
I would love to get this machine back in full operation and use it as my daily driver.
