Surprise! The 1957 Hotpoint washer is up and running!
turquoisedude
Aug 8, 2007
10,588
I've been keeping this one under wraps because I wasn't sure I'd get to it this year, but well, here it is!
Meet my first Hotpoint automatic washer, a 'basic' 1957 model!
When I first got it, I was so excited that I tore the top off without taking any other photos...
Here's a first look inside the machine. Note the concrete balancing ring!
Miraculously, the mechanics and electrics on the Hotpoint were all good! Timer, drive motor, and solenoids all worked.
But there was this hose issue to deal with....
The original hose was a custom-curve affair. I knew I had little to no hope of finding a 'stock' replacement...
So after a lot of head-scratching and ideas bounced around with Phil, I thought I could adapt some more or less standard plumbing parts to do the job.
First, the outer cabinet drain was replaced with a bathtub drain outlet.
Notice that it's holding vater!
1957 Hotpoint Solid-Tub Washer
Yay , Paul I am glad you are getting to this one, I know that it would have been a long time before I got around to this one.
The all porcelain cabinet was sort of a necessity if they wanted any durability at all since the cabinet is the outer tub on this washer very much like the Frigidaire Uni-Matics, ABC-O-Matics and Kelvinators also used the cabinet for the outer tub on early design machines, Keep us posted, John.
The adapted drain hose has more twists than an Alfred Hitchcock film...
I used a standard sink flange, cut down, spliced to 1 1/4 inch hose, reduced to a 1 inch hose and on to the pump.
There's a reason why I never worked in a nuclear power plant... LOL
Way to go Paul!  Your '57 is in really nice shape.  The center post looks great, and it sounds fine when spinning up.  Love your solution for the drain hose.  I would have done the exact same thing.
I feel bad that I haven't had a chance to scan those Hotpoint service bulletins yet.  Let me know if you still want them and I'll add them to this thread.
Ben
Wonderful machine and restoration Paul!!!! I'm thrilled otherwise everything works. I've used the bathroom basin sink drain port and tube trick myself quite a few times, it works perfectly. Just as a heads up, because I had to learn the hard way, you have to cut out the X in the center of the new drain sink opening, otherwise it gets clogged with lint overtime and slows the draining down to a crawl.
Hotpoint!
Real cool when I was small my parents had a BOL 55 hotpoint until 1961 than they got a near BOL 1961 model almost like your new surprise. The ones we had the tubs were a darker color. I love the short videos you made. Can you take a closeup of a control dial. On the 55 their was no pause before it went into a spin. On the 61 it paused for a minute before the spin. What does yours do? Keep us posted.
Best Wishes,
Peter
Robert - thanks for that tip about the 'X' at the bottom of the drain! I never would have thought of that.
Pete - as requested, here's a close-up of the dial. I'll spiff that up a little at some point (ie - when I figure out exactly where the Hoptpoint will go...I think a second row of washers will be coming soon to a laundry room in Ogden!)
Spin Pause question
Pete - Sorry, I didn't answer your question about the pause before spin on this washer. There isn't one! The agitate solenoid drops and the beastie starts a-sppinn'!
Hotpoint Docs
Ben, I realized that I never answered you about the Hotpoint info that you have but yes, I definitely want them! So will anyone else who's got a Hotpoint... LOL
