58limited
Found this at the side of the road. Tappan 40" Model HADV 668 7M
The good. Its complete and probably only needs burner/oven valve rebuild and safety valve rebuild. All storage bins inside the compartment on the left are present. Burner covers are there, and all other parts.
The bad: Tie down rope broke on a curve on the way home. Stove tipped over. The top (backsplash - which was not screwed on unbeknownst to me) flew into road and is bent, diecast trim broke with missing pieces. The clock lost its knobs and bezel but is otherwise unharmed. Timer works too.
Two knobs with their glass trim rings broke and the storage door latch knob broke. Porcelain chipped on left storage door.
This is still a good solid stove to fix if I locate the damaged parts - already sent a few e-mails to TOAC and other sources.
