testing the maytag atlantis
cfz2882
Feb 9, 2010
2,619
Belle Fourche,SD
got around to checking the 2000 vintage maytag atlantis i just
got from a junkyard;dry spin and wash went well but problem
was apparent when the wet spin came-would not pump out because
the belt was slipping on the motor pulley,motor can move on
it's base via plastic bushings that move in slotted holes-
there is a spring clip to provide some tension on the belt
but not enough-motor just sits where you position it on the
base-might be a spring missing somewhere?-if not i might have
to "improve" the design and add one...
