The copier/printer I would like
tomturbomatic
Gold Member
May 21, 2001
21,849
Beltsville, MD
You know those kind of sharp snap noises copiers make when they grab the sheet of paper and then deliver it? I would like a copier that makes BIG heavy solenoid noises like an old crash-bang Speed Queen washer.[this post was last edited: 8/18/2020-22:06]
big iron copy machines
My dad worked on copy machines for a bit around 1975-I think they were all Xerox back then.I used to drag copy machines home from the dump back in the '80s and 90s,American and Japanese machines with a big main motor and lots of solenoids,sprockets ,gears,cog belts.Salvaged lots of good parts.:)
All I care about is that the copier/printer make good copies without needing a ton of maintenance.
I did the HP Inkjet thing but got tired of ink cartridge nonsense.
Have had a Canon Image Class MF8050CN for the past ten years, zero problems. Takes four dry cartridges, like a color Xerox machine. Plus the ink don't run.
I have a Canon Image Class something-or-other model at work.  Got it several years ago on a sale price $269.  It's insanely heavy, barely managed to get it myself up the stairs.  The toner cartridges are $147 each (or $140 for Quill-brand), so total $588+tax individually for a set of four. Combo of the three colors (yellow, magenta, cyan) is $60 less than individual.  I use it as the scanner copy output and for whatever needs to be in color ... not as the primary printer, be too much consumables $$$$$.  The cartridges don't last near as long as the HP laser.  It needs all four cartridges changed now and there's no fundage due to COVID shut-down.
Well, I don't print much here, and last time I had to get cartridges I found them for about $70 ea online. Aftermarket, but they work just fine.
For basic B&W printing there are better choices, of course.
But for color, this thing is awesome.
Was historically an HP fan. I still maintain one old (2004) HP Inkjet printer just because wide carriage printers for B size 11x17 prints are 'spensive. I have physically had that printer apart at least 5 times in the laundry tub for cleaning. If there was a better wide format option then one couldn't pay me to have an inkjet ever again.
I had one all in one HP B&W LASER that was OK but it had lots of issues all due to software and drivers. I replaced it with a Brother and it is SO SO much better in every way but was about the same sub $300 price.
Sorry it doesn't clack though, I suppose one could wire in a big contactor to pull in for the audible effect as each page is run ;)
