the Haier problems
bpetersxx
Jun 6, 2008
1,811
laf in on the banks of the Wabash River
well
Haier XQG50-31
the dispenser flushes the bleach side in the 2nd 3rd and 4th rinse portions of the cycle
guess that is normal
the water fill valves are slow to fill until hot water is run thru them
also they sometimes do not close even with no power to the washer
and the dryer part blows the safety fuse
but do not use that as it uses loads of water
Haier XQG50-qf802
the fill to dispenser hoses cannot be tied up as it causes the fabric softener to dispense too soon
comment if you want me to post the rest of the video links here
Both valves are ornery about shutting off?  Do you have low water pressure?  Water pressure is what makes the valves close when power is removed.  20 psi is typically the minimum for proper function, and of course low pressure will make for long fill times.
