The Mechanical Restoration of the Youngstown Dishwasher
Unimatic1140
Administrator
Staff member
Apr 26, 2001
9,927
Minneapolis
In this thread I will chronicle the mechanical work of the Youngstown Dishwasher.
First on the list is the water system and it appears that there are three items in the water system that need to be worked on, the Drain Valve, the Mechanical Water Valve and Pump Shaft Seal.
So I started with the drain valve. It uses a rubber ball to seal up the drain hole, but the rubber ball couldn't not sit completely down and seal the drain hole because of hard water deposits. The drain valve is cast out of Brass and simply seals (or ties to) with a rubber super ball! It is very cool and VERY primitive, I just love primitive parts in our machines. Check this part out...
Say YAY for Youngstown
Robert:
It's amazing how simple engineering can be so efficient! You've done a great job cleaning up those parts. Coming from what I perceive to be the "hard water capital" of the US, I know how pesky those mineral deposits can be!
Venus
Hey Culligan Man!
Just give him a jingle and buy yourself a water softener. You won't be sorry. Once you have one, you'll never want to be without it. No self-respecting appliance aficionado should put hard water in a machine.
You won't believe how good your clothes will feel the first time you wash them in softened water (assuming you remember to use far less detergent than you're used to).
Also, your skin won't itch anymore after showering because there aren't any mineral residues ground into your skin when you towel dry.
And the softened water feels oh so...slick and slippery...when you shower. ;)
P.S. Once you have softened water, you can't use Jet-Dry in a dishwasher, or else the water will suds up and lock the pump. Not to worry, though. Dishes dry spotlessly.
Robert,
Thanks for the pictures.
You are getting to the bottom of things!
I love the Ball! That does the trick! What more do you need?!
You know, as far as "what is old, is new again," the HE3T that I have, and all of the other Whirlpool names uses a "Eco Ball" for the drain. So no water can leave, or backwash enter, etc., no matter what position the drain hose is in. I wonder if they go the idea from the Jamestown dishwasher.
Your work is really fun. I enjoy watching you redo this machine!
Can't wait for your "virgin" load.
Thanks again!
Brent
Isn't wild how Brass shows up in Roberts D/W?
They had to use Brass because SS was too expensive and scarce in the 1940's and the plastics available then would never have stood up to all that hot corrosive D/W waste. You might have gotten away with Bakelite but bakelite molds cost even then $50,000 to produce. Brass was much cheaper to mold!
Aluminum would have failed quickly too.
There was a metal blend developed at the turn of the century which was the equivalent of SS today it was called MONEL metal.It had a nickel appearance but I bet it was more expensive than Brass or Bronze.
I'll have to dig up some stuff on Monel metal. It was used in the steam kettles on Titanic and they are as shiney today as when the Ship went down!
Its a gravity drain Steve. Pete the James dishwasher has a pump, but the Apex has also has a gravity drain like the Youngstown.
Hi Robert,
Thanks for the restoration pictures I always enjoy them; do you use Adobe Photoshop? The Lime Away product seems to be great stuff; I have never seen it in the UK who makes it?
All the best.
Hugh
Robert:
The dishwasher is a wonderful machine. I am glad you finally got one and fixed the problem so quick. I usually can diagnose real quick, and just "know where to go" to git-r-done.
Steve
MONEL
Jon, Monel was also called German silver. The John & Mabel Ringling house/museum Ca Da Zan in Sarasota has kitchen sinks made of this. The kitchen there is neat with both gas and electric ranges from the 20s. A friend gave us his ooooold water heater installed in the late 1930s with a Monel tank. The tank is still good, but other parts began to fail after 60+ years.
The Mechanical Faucet
If all goes well (and as many of us know it usually doesn't) I hope to be washing the virgin load of dishes by the end of week in the Youngstown. I've got the necessary parts to repair the water inlet valve which I'm going do this evening, pictures to come. I'm going to rename the water valve the "Mechanical Faucet" because that is what it really is!
wouldn't want the power to go out while the valve was open
That's right Steve, and to make it even more exciting for our modern housewife, if the power goes out and the timer cam has push up the lever and opened the water valve, there is absolutely no way to manually turn the timer to off to close the water valve.
Get your boots on boys!
Power Failures & Jammed Timers
Was this serious flaw a known thing at the time? There's nothing in the user manual about troubleshooting or "in case of difficulty." What, Youngstown Kitchens had a trained service tech available 24/7 on every block, LOL!?
