The SQ still uses a shit ton of water, especially if one selects the three deep rinses over the eco rinse option. That's the whole point, isn't it? Having that choice to either go with the water saver option or not to.
The same applies to Fisher and Paykel. Depending on the model most of them give the option of an auto sense fill or manual water level select. The default, to my understanding, is the intuitive eco option that comes on every time the machine is turned on. This option is supposed to only fill the washer through auto sense and with only as much water as is absolutely necessary for the load size and fabric mix to be washed. In the manuals it is described as using almost as little water as a front loader would do for the same size and type of load. The load is fully saturated, but not to the point that it is fully suspended in the water. Combined with the eco rinse it is meant to be almost equivalent to a front loader wash in water consumption and wash action. However, if intuitive eco is deselected, the washer fills and operates like a regular top loader. Both the straight vane agitator and low profile wash plate are designed to allow for such low water volume and still thoroughly agitate clothes without excessive wear and tear.
F&P also offers five different water temperatures, which the machine will mix and sense. With hot being tap hot, hot/warm equal to 40C (104F), warm 30C (86F), warm/cold 20C (68F) and cold being tap cold.
Now, getting back to the 2018 SQ model using the agitub system. A picture of the agitator for the new model was posted earlier. It really dosen't look like that much. One would think that with an agitub they ought to incorporate structures in the spin tub that cause more water turbulence when the tub is spun to create agitation. Will the clothes still move through the water as vigorously and in the same toroidal movement with the new system?
The service tech response mentioned further regulatory compliance making desing changes necessary. However, many markets that SQ sells to do not apply American regulations. Thus, one would assume that SQ may still manufacture regular, belt driven agitator washers for overseas consumers. At least I would hope so. By making such a fundamental change to their top loaders, I feel that they are dumbing down their design. [this post was last edited: 11/8/2017-04:03]
