The Norge
bobbyderegis
Dec 30, 2005
1,606
Boston
Hi All!
Now that my Christmas concert is over, I thought I would tackle the agitator on the Norge. The original one is broken at the top and is frozen to the shaft.
Bobby in Boston
So now I need to remove the cracked agitator. Nothing made it budge, so since it was junk, I took the Dremel to it.
I worked at it for over an hour. I have never seen an agitator so frozen onto a shaft. I bet the crazy Youtube washer killer couldn't get this one off!
As I'm doing this, I hear someone knocking. I put down the Dremel and head for the front door. As I pass by the GE Filter-Flo, I realize the knock was an unbalanced beach towel that I had thrown in!
I finally get the agitator off. I could have cried. The shaft looks like something rescued from the wreck of the Titanic!
So now I ask the experts:
Where can I get a new shaft cover, drive hub, and gaskets? I assume I can remove the tub, pull the drive hub off and then the shaft cover without changing or pulling the entire tranny. Anyone willing to offer suggestions? I don't want to see this poor old girl go to the scrapyard!
Bobby in Boston
Bobby, I bet Larry at Modern has a drive block, those might even still be available. You probably can get away with not replacing the hub and shaft as its going to be a monster of a job to get everything apart.
Bobby, I see you've become an ace mechanic very quickly.
Don't you have a mini-basket to successfully spin a lone beach towel?
What vintage is that Norge? I see it says 20 pounds. It's much like the '67 Signature my mom had, but that one was an 18-pounder and had a slanted control panel.
The machine looks very clean otherwise. Good luck with it. You have earplugs handy, right?
71 or 72
I used one like this I got from lightedcontroldial in Virgina for over a year...until I got tired of my hubby complaining about how rough it was on his clothes.....I still think it is THE BEST washer ever made!
Making progress..........
Larry at Modern has some parts. Does anyone know if there are four or six bolts under the wash basket? He doesn't have a diagram of this model, an LWA 2040 A00.
Bobby in Boston
If your mom had a 18pounder, that was a Westinghouse. Wards carried either the Norge 20-22lb, of the 18lb Westy. Of course the Norge ran circles around the Westy and its lousy indexing tub.
Lotsosudz
I'm sorta missing my norgetag
In reply to Post# 398578-12/9/2009-14:39 by Norgeway.
I had a PAV Maytag, which a lot of ppl around these parts don't like, and yes it only lasted 10 years, but I'm sort of missing it.
I miss the true 2-speed selectable agitate/spin combos
I miss the basket size
I now realize that it was far more gentle on clothes than my DD Admir-pool is, especially since most of the time on the Norge-tag I used a long cycle, slow agitate, fast spin.
Love the older, slanted consoles. How Whirlpoolesque!
Since there are only three tub bolts, I assume the agitator shaft cover would have six bolts, evenly spaced around the three, no?
Bobby in Boston
OMG that avocado set is going to give me nightmares. Excuse me while I finish shuddering. I was hoping never to see them again. I'm glad to see they're sitting somewhere and not actually in use by anyone.
I thought my mom's 18# pair were '67s but her dryer had the 3-position drop down door.
