Well, the new caps arrived for a couple of RR's - the 6W and the 10. The 10 is now back in business, all 4 glorious programs. But the 6W (who was getting caps as preventative maintenance) needs an HV diode and a triac (broken base). Ugh. With the new caps we were back to digital goodness, but playing with it for a few minutes, it was working 1 out of 10 times (thought it may have always had this problem)
The blues? Ben and I have passed up these machines in their smashed up or defaced state, good components and all. And when we picked up the Speed Queen we passed up the perfect repair unit...two hours away. Dang it.
For those who are curious- we hit up the local Amana dealer where they let us in the backroom and took our fill of RR info this evening.
The RR-1: Two buttons, START (blue) and LIGHT (green). The timers add so one will expire and the other will start if they are both advanced.
The RR-2: Three buttons and timers are redundant.
The RR-3H: Has a LOCK slider below the front vent. Perm Mag? Dunno.
The RR-4 Uses a Permanent Magnet for the magnetron and has no defrost.
The RR-4D Has Defrost and includes the gov't mandated dual safety interlock board req'd post Aug of '74. If a relay should stick or someone jambs in the START button and other parts also fail, the unit will not operate with the door open and a thermal fuse will pop.
The RR-4DW Same as above, but the metal stirrer is air driven. No more add'tl motor.
Anyone know the difference between the RR-6 and 6W?
Cory
Cory
